Building a Guitar Amp Cabinet - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 29th May 2012, 08:45 PM   #11
Austin Translation's Avatar
Send a message via MSN to Austin Translation Send a message via Skype™ to Austin Translation
FWIW you can safely run less impedance than optimal on a tube amp but don't go much higher- You can run 4 ohms or even two ohms no prob but dont try hooking up a 4x12 cab in series for 32 ohm. The opposite is true for solid state.
The load is reflected back to the tube, if you have 5k output transformer with 8 ohm speaker then you hook up 16 ohm speaker (two eight ohm in series) the output tube will see a 10k load instead. Alternately if you hook up a 4 ohm speaker (two eights in parallel) then you will load the output tube with 2500 ohms instead. This (less ohm load) usually results in more second harmonic distortion which imo sounds good for guitar.
Not hooking any speaker up at all with the amp on can hurt the output tube and make it arc inside. However completely shorting the wires is harmless.
Building a Guitar amp lynchy217 Instruments and Amps 146 16th May 2011 08:40 PM
guitar amp enclosure/combo cabinet Aidan135711 Multi-Way 9 6th May 2010 08:43 AM
Beginner - Building a bass guitar cabinet richmoore1998 Multi-Way 3 27th December 2008 03:31 PM
Guitar Amp Speaker Cabinet dsavitsk Instruments and Amps 5 28th April 2007 10:42 PM
Building guitar cabinet- help? otokomae Instruments and Amps 8 20th October 2005 09:41 PM
Copyright 1999-2017 diyAudio
