Guitar Amp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st May 2012, 11:31 PM   #1
Default Guitar Amp
Hey!
What is the ultimate diy guitar amp now? The amp should have a clean/warm sound and be easy to build. It can be tube or solid-state...
Ty for your response and help.
Old 2nd May 2012, 12:59 AM   #2
Enzo is offline Enzo  United States
Who is the most beautiful woman? What is the funniest joke? What is the best tasting food?
The ultimate amp depends very much on what you want the amp for, and within catagories it certainly is still a matter of taste.
I myself am not very familiar with solid state kit amps available, I suspect there are some fine ones. Tube amp kits abound, and probably the most popular one is to clone the Fender Deluxe or "5E3."
Kits are good for the novice because they come with everything you need. Or at least they do if you buy a complete kit. You won't get it half built and realize you never ordered some part. Many of them come with premade chassis ready for your build on the interior. Transformers already selected, etc etc.
Of course you can build from scratch, find or make your own chassis, buy transformers and other parts from suppliers of your choice. But you want easy to build, so I'd steer you towards a kit. Explore kits, as some come with more detailed instructions than others. Kits come in everything from just the electronic parts, complete chassis kits, or complete amplifiers with cabinet and speaker. Kits come in the very basic like the Fender Champ, up to fairly complex, like Twin Reverb.
Kits are not really a way to save money, they are not cheap parts discounters. A kit can cost you about as much as an amp ready made, but you get the satisfaction of building it and learning something. Some kits cost more than others, and some of that difference is in the parts. Off the top of my head, some kit purveyors are TedWeber, Mission amps, Mojo, and many others.
There are web sites devoted to building guitar amps, the AX84 site is popular and covers a number of proven designs, and hosting forums full of people who have built them or are building them.
Old 2nd May 2012, 04:07 AM   #3
Originally Posted by axl666 View Post
Hey!
Well, it just seems to me the "ultimate" guitar amp project would be a D inspired Over Drive Special ; based loosely on the Fender Twin... Not sure how easy to build as a "DIY", but I'm thinking of doing one of these as my next project...
I would build a Fender Twin, and that is supposed to get you like 90% there....
-g
Old 2nd May 2012, 03:55 PM   #4
Tubelab_com's Avatar
The 6550 seems to be fully characterized for heavy metal!
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 2nd May 2012, 04:55 PM   #5
doozerdave's Avatar
I can second that. My dual 6550 modified Fender Super Reverb is a monster for metal. It also turned into a 1x15 combo sitting on top of a 2x12.
Not exactly a simple DIY project though. SE 6550 on the other hand (my next project) isn't too bad.
-Dave
Old 3rd May 2012, 02:48 AM   #6
shanx is offline shanx  Canada
Hi axl666, I thought from your name you may be going toward the deathmetal side..
But if you're looking from clean to warm sound, and easier tube build would probably be a Class A type low watts, I would look at early Fender Champ types or similar. Plenty of kits and parts available to support it. Don't know if you have experience with high voltage stuff so be sure you know what you are doing with tube amps circuits first..
My ultimate build (I hope one day) will be something like Trainwreck Nancy, she is all nice manners til you crank her up, and then she is downright dirty.
The ultimate build is one that works, and also ends up sounding the way you want, after much much fiddling around with it.
Old 7th May 2012, 08:03 PM   #7
I made this schematic, please check it. I work with electronic every day, but never designed an amp. So i am quite new on audio electronics.
I have an GT-10 multi effect so i need a good clean amp. I wil use NE5534, OPA132, AD823 or AD744 for the preamp. Any suggestions for the power amp?
Sorry for the late reply.
Old 10th May 2012, 08:13 PM   #8
(OK. Typing too much makes the session expire, and the text to be lost when clicking "Preview". Lesson learned 'till I forget again.)
First, I recommend you a good read on audio amplifying. Begin with small signal (preamps), and leave power for later. You really can get a working amp, but it can sound horrible, wasting your efforts. Besides that, you have to know what you're doing before dealing with power stuff, because devices and fingers burn.
Now on the circuit:
The first two opamps will latch at one of the power rails as long as the amp is on. Unless you reversed their inputs .
What are you trying to do with the first three opamps? They seem overkill for this section (buffer and gain control).
The connection between the two first two opamps inputs doesn't look sane, specially for lower frequencies.
The equalizer will probably have quite less effect than intended, specially when cutting frequencies, due to the summing at the end.
Do you really need so many eq bands? What do you expect to have below, say, 60Hz? Did you calculate the overlap between bands?
The excess devices and some resistor values point to noise and low input Z (not for the GT-10, but for when you bypass it for dry signal, which is useful sometimes).
Besides, your drawing doesn't tell whether crossing lines are connected or not. We can guess, but we really shouldn't.
After you understand all those preamp points, study about guitar signal processing, which is a whole different beast - specially when it comes to tone and linearity. Remember to read about "tone stack" at some point (don't begin by it).
Best regards,
Emerson
Old 10th May 2012, 09:04 PM   #9
Agree with Emerson that there is a lot (too many) opamp stages for what is needed. If you already plan on using the multi-effects at front end, then I expect most of the sound shaping you would want done by that. You said clean, so you need just a simple buffered preamp in, maybe with adjustable gain, a tone stack or eq stage and then out to your power amp (maybe through another op amp stage, depend on tone stack's output). The power amp could be a simple push-pull type with transistors. I have no idea what your rail voltage is from the drawing, and that is a big factor in determining the headroom and how clean it stays before clipping point.
I would back up a bit here, because this started out about what would be the best/ultimate DIY guitar amp that should also be easy to build. Now we are talking about design of it? That is a totally different thing. IMO if you are designing something to sound good but relatively easy build for a new DIYer, then I think that the above circuit would fall short on that criteria. 2 op amp stages running on single rail 18 V or so would easily provide a very decent pre-amp with a passive tonestack between.
Old 11th May 2012, 03:02 AM   #10
Hi Axl666, Sorry if I came across as critical to your design along with my advice. The guitar preamp needs to do only a couple of basic things. In general terms 1st stage should be a buffer of some sort, if you go with op amp (OP1)for that it would need to be setup as unity gain follower or could also do it with a jfet or mosfet .That takes care of the high impedance source from a guitar (if you plug directly in).
2nd stage should provide gain, and with op amp set up as a non inverting amp, calculate a gain factor about 100 to get you well into line level. You can put a pot in the amp circuit to vary gain like you have on OP2, but right now I can't figure out what your intention was on that 2nd stage gain circuit, can you please give a clarification there?
I would a simple tone stack after 2nd stage(you could add the graphic eq in later)
Power amps section: Design is typically done based on what load, wattage and power supply capacity is specified. Then you design from the power amp output back to the input line level.
Best regards, shanx
Wurlitzer 6150 Organ Tube Amp convert Guitar Amp ssombret007 Instruments and Amps 9 2nd January 2012 12:31 AM
Tube guitar amp for acoustic guitar? dagerman Instruments and Amps 15 6th April 2011 02:07 AM
1959 Pilot AA-908 Amp into Guitar Amp aronaut Instruments and Amps 6 19th March 2008 08:38 AM
ecl86 & ez80 - suitable for guitar amp? greenstax Instruments and Amps 20 22nd August 2007 10:10 AM
Copyright 1999-2017 diyAudio
