6L6GC / 6BG6 x4 Ultralinear Guitar Amp - Page 12 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 22nd August 2012, 01:46 AM   #111
Tubelab_com's Avatar
Two months for boarding? LOL
Face through the glass maybe?
I can see the Florida Panthers arena from by kitchen window. I have seen more concerts than games there, but I did see the glass break once. Minimal bloodshead though. Don't even remember who was playing.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd August 2012, 06:01 PM   #112
Cassiel is offline Cassiel  Libya
A pity, we need more funny members.
Old 13th September 2012, 05:34 AM   #113
Struth is offline Struth  Canada
Banned
Hi Guys
Ian, that circuit is pretty common in hifi and is referred to as "low-z Drive" in DSN-1.
As far as the 100W amp project goes, if the 300-0300V PT is used in the lethargic half-bridge mode, B+ will only be 430V. Power into a 5k-aa OT is limited to about 36Wrms. Why 5k? Is it because Hammond lists such a unit? The 1650N at 4k3 is more like what production 100W amps use with four tubes driving. This is rated at 60W hifi but supports 100W easily for guitar which does not require full bass extension.
The 1650R 5k is designed to match a single pair of 6550s or KT88s. The latter can use the UL taps without question. For either tube, use at least a 1k-5W screen-stop regardless of output wiring (UL, triode, tetrode). This same detail applies to all power tubes in guitar amps.
The typical 1650R app calls for 600Va and usually 300-350Vs with no UL connection. The low screen voltage allows you to beat the plate quite liberally but also requires a cathode follower or TX driver to push the grids positive for full output.
Have fun
Kevin O'Connor
FS: B&G Neo10 x4 Tenson Swap Meet 1 16th February 2011 11:42 PM
6bg6 and 8k opt power amp project Yaho Tubes / Valves 30 15th June 2010 12:42 AM
6BG6 = 6L6GC with top cap - cheap! ray_moth Tubes / Valves 6 31st May 2007 05:46 PM
Has anybody built 6BG6 or similar OTL amp? rnx69 Tubes / Valves 2 14th April 2004 01:25 PM
40WTriode/60Watt Ultralinear amp ashok Tubes / Valves 1 30th June 2003 11:17 PM
Copyright 1999-2017 diyAudio
