fuzz face help - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd April 2012, 09:23 PM   #1
Default fuzz face help
Hi. First post on this site, so bear over with me.
I recently buildt a bc108 fuzz face based on the schematic on this site:
Fuzz Central -- Arbiter Fuzz Face
Everything seems to work, it it cuts out if I play a little soft, between notes or if I turn the volume down just a little. Does anyone know what's wrong or what errors to search for?
(switch is wired as suggested here:
http://www.diystompboxes.com/smfforum/i ... _next=prev
There's also a led with a 1 k resistor that doesn't appear in the schem), all the ground points are soldered together and to common ground.)
Old 4th April 2012, 04:24 AM   #2
Simon B is offline Simon B  United Kingdom
That led will be drawing about 7mA, so if you're running from a battery you'll dramatically shorten its life.
The second link you give:
doesn't work for me, so I can't see how you've wired it.
Assuming that's all ok though, and that you haven't got a defective component, all I can think of at the moment is that you've perhaps got a wiring error - how is it constructed? Pcb? Vero/Strip board? Dead bug?
Maybe a close up photo would help, if you can take one and post it? Better still two photos, one of each side of your board, assuming your using one.
Check and re-check that you've got the right connections between the right value components in the right places and that you've got E, B & C correctly oriented on your transistors.
Old 4th April 2012, 04:42 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Which one did you build? There are 3 different schematics there. What voltages are on collectors of transistors? On bases and emitters? It would help to help you to diagnoze your problems.
The Devil is not so terrible as his math model is!
Old 4th April 2012, 08:52 AM   #4
Hi, thanks for the feedback guys.
@Simon B: Not running a battery (using a t-rex fuel tank). I assume you mean the link doesn't work, try this:
True Bypass - Why not ground the input AND the output?
the switch seems to work fine. It's constructed using a vero board (i think thats it, the type with holes and no strips a.k.a. test board) and I'm quite confident the solderjoints are good, though I woun't rule anything out at this point, and shouldn't that make it cut a bit at random?
@Wavebourn: I buildt the second one on the page, the NPN one, using bc108 tranies. Someone at another site suggested it might be 8.2 biasing resistor on Q2 being wrong? I'll see if i can't get some measurements when I get home.
Old 4th April 2012, 12:39 PM   #5
Seriously,
if you can, post pictures.
Old 4th April 2012, 01:07 PM   #6
Hi
I guess that the battery is sagging because of high current taken from it...
regards, Pawel
Old 4th April 2012, 04:35 PM   #7
Check the bias - sounds like it's gating from a mis-bias.
True the LED is sucking more current than the FF, it's still not likely a low battery. Do check it with your other measurements.
Old 4th April 2012, 06:30 PM   #8
It's not batteries guys, as he says above, he's using a power supply.
Voltages and pics will be the way to solve this one I think, so it's up to you Eugene. Maybe show us your vero layout too if you can.
Old 4th April 2012, 06:41 PM   #9
Wavebourn's Avatar
Right. That's why measurements are needed.
Old 10th April 2012, 08:41 AM   #10
right
maybe check 100k to base Q1 connection? Or input cap is leaking?
regards, Pawel
Fuzz Face Shamharoth Instruments and Amps 16 2nd March 2012 06:28 PM
Problem with Fuzz Face bschrecko Instruments and Amps 3 1st October 2009 04:21 AM
Fuzz Face problem bschrecko Instruments and Amps 3 19th September 2009 03:39 AM
Fuzz Face DIY: need more fuzz ThomasDIY Instruments and Amps 12 17th September 2009 04:06 AM
Fuzz face problem jancooo Instruments and Amps 9 1st December 2006 12:02 AM
Copyright 1999-2017 diyAudio
