Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th April 2012, 01:42 PM   #11
doozerdave's Avatar
Glad to hear you found the problem.
My silver face Super Reverb has them inside, so I assumed your TR was the same.
-Dave
Old 8th April 2012, 04:22 PM   #12
Cheers! That makes sense. Mine was the final SF design TR so maybe your SR is an earlier production as well
Old 12th April 2012, 07:28 AM   #13
Dick Deviant,
Those 470 Ohm 2W Carbon screen resistors have a bad habit of going open circuit, usually after they have drifted in value (usually high) by as much as 200 or 300 Ohms.
One of the 1st things I do on any Fender is strip out those screen resistors and fit 1K 5 Watt "Rats Coffin" style resistors in their place. This helps protect the output tubes and some claim it gives you a little more "touch responsivity" when playing. I never noticed that but I do think the amp breaks up a little earlier, that is you don't have turn it up quite as loud to get a little power amp compression.
I know that many Fender techs do the same thing.
Ian
Old 12th April 2012, 07:47 AM   #14
Sounds good Ian.
This twin I'm running now sound perfect to me though so I want to keep it stock. If I ever come across a cheap one that is dead or someone else has started modding then I will be very interested in testing out all these little tricks for break up and tone.
All the same thanks for the tip!
simple SE blowing fuse when 6.3v attached with no tubes in place. Reidy- Tubelab 28 20th May 2010 05:50 PM
Fender always taking care of tubes.... Cassiel Tubes / Valves 2 28th May 2009 02:30 PM
Best place to get Shuguang 300B tubes lowtherdream Tubes / Valves 15 7th May 2009 06:43 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Where is the best place to add tubes in this system? orangedog Tubes / Valves 2 2nd February 2004 02:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
