Broken Mesa Dual Rectifier - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th February 2012, 12:09 AM   #1
Default Broken Mesa Dual Rectifier
I have been doing some work on an audio interface for recording and in the process, I made a bad connection... I shorted out the speaker on my Mesa 100W head for several seconds. Now, when I turn it on, it is noisy even when the output is set to zero. Would you recommend just taking it to a pro or trying to fix it myself? There sounds like there is something loose on the inside. It still plays but the signal to noise ratio is worse than I remember it being.
I have experience with electronics, but I am by no means a pro. Any help is appreciated. Thanks.
Last edited by Littlebilly91; 27th February 2012 at 12:20 AM. Reason: Updated Amp Status
Old 27th February 2012, 12:20 AM   #2
kevinkr's Avatar
Since this is a musical instrument amplifier I'm moving it to Instrument & Amplifiers per forum policy. Please see the header at the top of Tubes / Valves..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th February 2012, 04:21 PM   #3
Since you don't have experience i would recommend taking it to a tech. but it could be either power transformer or output transformer thats damaged or maybe both. may also be worth changing the tubes.
Old 27th February 2012, 11:33 PM   #4
Minion is offline Minion  Canada
Sounds like a fried output transformer , a pretty expensive fix , get it to a tech .......
HELP HELP HELP mesa rectifier ethan Instruments and Amps 1 16th October 2009 04:15 AM
dual rectifier clone.... rtill Tubes / Valves 3 16th February 2009 02:54 AM
Mesa Dual Rectifier Mods...caps? ttrentt Instruments and Amps 9 23rd June 2006 03:39 AM
Mesa Boogie Dual Caliber DC-3 schematic? Netlist Instruments and Amps 0 28th February 2004 10:45 AM
Are dual rectifier bridges useful? runebivrin Solid State 25 24th February 2004 12:56 AM
Copyright 1999-2017 diyAudio
