Help needed with direct output (DI) for bass amp - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd February 2012, 04:18 PM   #11
Originally Posted by funk1980 View Post
Worked like a charm! There is no significant tonal impact on the signal and it even allowed me to implement a separate volume control for the DI output. So thanks geraldfryjr!
I was wondering if it's good practice to use build-out resistors of, let's say, 100 ohm, to prevent short circuiting the outputs in case of e.g. cable failure.
Most opamps are S/C protected anyway, the usual reason for including the resistors is to prevent instability with certain types of opamps with certain loads.
However, adding a couple of resistors won't do any harm, so you may as well.
Nigel Goodwin
Old 3rd February 2012, 10:53 PM   #12
Good Show,funk1980!
I am very happy that this worked and that I have been of some good assistance to your project !!!
Keep on DIYin' !!!
jer
Changing bass amp output transformer Leb Instruments and Amps 8 27th September 2010 11:28 PM
Resident SWR bass amp gurus needed chicago_mike Solid State 1 22nd December 2008 09:56 PM
Direct coupled PP 2a3 amp - maths needed!! Eusebius Tubes / Valves 6 22nd April 2007 08:32 PM
DI guitar direct input box - increasing gain? bubbamc119 Instruments and Amps 10 30th June 2005 02:22 AM
Building A Direct Output Line For An Amp MrGuitardeath Instruments and Amps 11 30th October 2004 07:39 AM
Copyright 1999-2017 diyAudio
