Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 19th January 2012, 03:32 PM   #1
Default CARLSBORO COBRA BASS COMBO (15INCH SPEAKER)
I've just bought (cheaply) one of these but it wont come on! I knew this when I bought it and thought I might have a crack at repairing it BUT the damn thing is proving difficult to access....can anyone give me some advice about how to remove the amp section please. Also, having changed the obvious plug fuse, my next step was to examine the slo-blo fuse....but where do I find it??????? Any and all help is appreciated.
Old 27th January 2012, 07:33 PM   #2
The control and pre-amp section is built on the front panel - and the power supply and power amplifier is built on the rear panel.
Each is secured with 2 screws on the cabinet side panels (2 each side). The mains slow blow fuse is integral with the IEC mains inlet connector - in a small drawer that can be levered out with a small screwdriver.
These are very straight forward amplifiers to work on - and suffer from a few 'standard' faults that are easy to find and fix.
So check the FX insert jack sockets - dirty switch contacts on these jacks will interrupt the signal, intermittently or permanently. Look at the bridge rectifier - solder joints can be broken - and short circuit failures can also occur. Output transistors can fail - as with any power amplifier of course.
John Audio
Old 2nd February 2012, 06:42 PM   #3
Thanks for that....but I'm still having trouble removing the 'inners'. Its all loosened up and I can move it but it wont come out back or front! Help!
Best tube combo for an electric bass.. Alexontherocks Instruments and Amps 6 8th October 2011 12:56 AM
Trace Elliot V-type Bass Combo bostjancek Instruments and Amps 6 7th July 2010 12:10 PM
OB bass bin for Altec 511B/902-8B combo... chops Full Range 32 7th December 2006 08:19 PM
BC Speaker 15INCH NDL76 spuddy42 Multi-Way 1 21st November 2006 06:09 PM
Polk (Cobra) Speaker Cables Peter Daniel Multi-Way 11 2nd February 2005 08:03 PM
Page generated in 0.06417 seconds (73.57% PHP - 26.43% MySQL) with 10 queries
