Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 15th January 2012, 05:17 PM   #1
Default power transformer specs
Hello,
I noticed that some tube amps, Fender Champ, have power transformers with ~660v @~100mA and others, Bassman, 700v @ ~400mA.
My question is this:
Can any transformer that satisfies a voltage requirement on the plate work? Like a smaller, 440v transformer with higher current. I am confused why the voltages would be stepped up so high to use only 305V on the plate for a Fender Champ.
Thanks Gurus...
Old 15th January 2012, 05:23 PM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
There is an upper limit of course that a tube can run on the plate....You can run tubes on a considerably lower value of plate voltages, it all depends on plate "curves". This is how you design a tube amplifier.....by selecting bias points with tube "curves". One selects a point along these curves which is most 'linear'....it's a designers call.
__________________________________________________ _____Rick.........
Old 15th January 2012, 07:31 PM   #3
DF96 is online now DF96  England
In some cases the transformer secondary will be centre-tapped, so 660V is actually 330V.
transformer specs magelord04 Power Supplies 3 1st August 2007 04:19 PM
Transformer Specs cammy666 Tubes / Valves 1 25th June 2007 09:47 PM
Transformer Specs Gunny Instruments and Amps 1 17th January 2007 05:52 AM
getting the specs on a transformer pango Tubes / Valves 4 18th December 2006 01:39 PM
looking for transformer with the following specs? matthew2456 Tubes / Valves 4 22nd August 2006 09:58 PM
Page generated in 0.07634 seconds (65.88% PHP - 34.12% MySQL) with 11 queries
