| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I was hoping someone here could help me out with my issue.
I'm having difficulty wiring up my 4x12 guitar cabinet. It has a stereo/mono switch and i think thats where my problem lies.. My 4x12 cab has 4 wires total from the input jacks, in two sets. Left and right, stereo/mono. I have Four matching 16 ohm speakers in the cab. I started the wiring with the Positive from the mono (right) side of the input jack like in the diagram. I left the stereo (left wires) unhooked and completed the loop with the Negative from the same mono side as when I started. Followed the diagram to the t only there was that other set of wires from the stereo side of the input jack. I figured I wont be using stereo so It wouldn't matter if the wires were left unhooked. So I switched my amp to 16 ohms, cab to mono and nothing....I think I could just barely hear my tubes distorting when I played, it did not sound too good....... ![]() So my drummer wired it his way and got it working. He said it should be 8 ohm, the cheap-o meter said 10. Switched amp back to 8 ohms and it works. I would like to get back in the cab if there is a more proper way wiring, so please reply with any info you may have on this, Thank you. |
#2 |
If you have four 16 ohm speakers, you can:
wire 2 in parallel for 8 ohms, and wire the other 2 in parallel for 8 ohms. Then wire those two sections in series for 16 ohms -or- wire those two sections in parallel for 4 ohms, which is all speakers in parallel. You cannot wire them for an 8 ohm impedance.
Single-Ended Tube Amp Kit Last edited by scott17; 15th January 2012 at 06:37 AM. |
#3 |
What 'e said.
You can't connect all 4 speakers and get 8ohm. A 10ohm DC resistance would indicate closer to 12-16ohm nominal impedance, so I'd leave your amplifier set at 16ohm while driving this cabinet. Chris |
#4 |
Any diagrams floating around?
A few guys told me to just remove all stereo wiring from Jack plate and just run Series/Parallel from the Mono side of the cab. Sound ok? |
| Guitar Cab Help | Trooper46 | Instruments and Amps | 28 | 21st June 2011 11:57 PM |
| Thiele guitar cab vs. ported guitar cab | qingcong | Multi-Way | 2 | 9th January 2011 03:32 PM |
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| Guitar Cab Conversion | givethemrope | Instruments and Amps | 3 | 16th August 2006 03:03 AM |
| bass guitar cab | random_id | Multi-Way | 6 | 22nd July 2004 11:30 PM |
| Page generated in 0.07801 seconds (76.99% PHP - 23.01% MySQL) with 10 queries |
