Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th January 2012, 07:28 PM   #1
nonsuchpro's Avatar
Question Isolation Cabinet for guitar
Hey all.
I am about to build a 12" isolation cabinet for guitar. I know that for the best results you want to create a labyrinth and bottom ports for depressurization. Has anybody built one like this? Here's a video explaining in more detail what I'm trying to make. Basically I need some plans/diagrams.
Rivera Silent Sister Iso cab explained by Paul Rivera - YouTube
Thanks!!
My Studio
Old 9th January 2012, 05:58 PM   #2
nonsuchpro,
Are you wanting a portable cabinet or stationary/built-in? I am currently designing a built-in ISO box to float inside a walled-up chamber in one corner of my home studio. The reason for the outer chamber is because the ISO box will be ported/vented and I want to minimize sound transfer. The box would be approximately 24"x24"x7'. I would have more than one speaker inside (i like to use 12", 10", and 8" spkrs). There would be a Shure SM57 on the spkr (one each), and one AKG 414 at the other end of the box.
I've attached a drawing of the ISO box with two spkrs. It appears on its side, but would actually be in a vertical position in the corner having the speakers aiming downward with venting on both ends of the box. There would be no directly opposing surfaces inside the box - hence the odd shape. Also, every surface would be insulated - inside and out. The inside of the outer chamber would also be insulated.
I'm also on the hunt and eager to learn about toggle switches. Particularly one that will allow me to select 4 or 8 ohm loads from the speaker(s), given the various amplifiers I will use with the ISO box. Using a dummy load resistor on one side of the switch (with the spkr on both sides) should accomplish this task. But the switch is yet unknown.
Good Luck!
Old 10th January 2012, 07:38 AM   #3
nonsuchpro's Avatar
Originally Posted by bsamusic View Post
nonsuchpro,
Good Luck!
Cool man... looks good. I wish I could see the inside of the Rivera SilentSister's labyrinth. I'm sure it's like a maze.
My Studio
Mechanical isolation of driver from cabinet LineArray Full Range 71 8th December 2011 12:39 PM
Cabinet Damping/Driver Isolation Summary? stephenmarklay Multi-Way 2 1st January 2010 03:07 AM
isolation transformer won't supply filiments - 1968 Harmony H400A tube guitar amp tonebrulee Tubes / Valves 7 9th April 2008 05:33 PM
guitar cabinet pinky78 Instruments and Amps 1 10th November 2006 07:53 AM
Guitar Cabinet sub_urban Instruments and Amps 2 1st September 2005 05:32 PM
Page generated in 0.08621 seconds (71.40% PHP - 28.60% MySQL) with 11 queries
