v1 tube keeps going microphonic help! 5e3 build - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd January 2012, 10:32 PM   #11
So you have another amp to try the tubes in. Are they microphonic in that amp? It might be a solder joint as been suggested if the tubes work in the other amp.
Old 4th January 2012, 04:19 AM   #12
Send a message via Yahoo to fenderkid
no there micro . all joints are good . all new resistiors/caps . didnt heat any thing up in soldering .
i wounder if its b/c i using my pedals on the high input (ts9's) and its just to much for v1 . thanks for all your help guys .
Old 4th January 2012, 12:17 PM   #13
Trout is offline Trout  United States
Trout's Avatar
In my experience, 5E3's are notorious for microphonic type issues.
You can even tap on the wires at V1 and hear it, heck even most capacitors in the first stage often display noise when tapped on.
Most brands of tubes regardless of NOS or current production will be sensitive to this and really, I would not worry a lot about it.
As long as you do not get any audible artifacts while playing, let it rip!
The only tube I have found that seems to tame this somewhat is the latest TAD 7025 low noise edition. Still microphonic, just not nearly as bad as the others.
Now if the tube is causing the amp to squeal, its no longer suitable.
Old 4th January 2012, 12:43 PM   #14
GloBug is offline GloBug  Canada
Banned
I agree, I also had a 5E3 clone that would make a noise if you tapped on the tube, yet was not an actual problem.
Old 4th January 2012, 01:26 PM   #15
Trout's Avatar
I just serviced a Fender Re-Issue last week, it was also very sensitive to the slightest tap anywhere near V1. It is just the nature of the beast in this case.
That said, it was a real sweet sounding amp, almost as good as my 5 year old personal amp.
Edit,
I might add that leaving the tube covers off can help as well, I found them to be the source of some noise/tingly sound due to them fitting to closely on some tubes.
Problem with high voltage in 5e3 build bagudan Instruments and Amps 46 11th April 2015 07:25 AM
5E3 Build Problems Cont'd Glowin Plates Instruments and Amps 6 10th July 2011 05:23 PM
5E3 Tweed build problems Glowin Plates Instruments and Amps 10 3rd July 2011 04:52 PM
Tube Oscillation or Microphonic Question Trout Tubes / Valves 6 29th December 2005 04:18 AM
Copyright 1999-2017 diyAudio
