| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hey, guys. I haven't posted to this site in 10 years or so! Good to be back!
So, i'm looking for advice, both opinion and technical... I have a Leslie 125 amplifier that's not in use. I'd like to make my first guitar amp project out of it. ( i've rebuilt / repaired a dozen amps at this point, so i'm not a total newb ). I'm bouncing around between what it would turn readily into, that's worth building. I'm thinking something like a Fender Tweed Deluxe or Bassman. Here's the schematic of the amp http://www.hammondb3organ.net/schema...ie/125/125.gif It's supposedly 20 watts, but what i don't get is why it's only 20 watts, when it seems like it could do more based on the components. Don't 2x 6L6GC amps put out 45-60 watts, depending on how they are wired? I've read that this amp makes a nice tweed deluxe, but the Tweed Deluxe uses 2x 6V6, and this amp seems capable of more... but i don't want to burn out the transformers by turning it into a tweed bassman when it's not capable of it. Also, the leslie is solid state rectified, and the old tweeds were all tube rectified ( and i see no 5v taps on the trafo, so i guess i'll be sticking with SS). Any opinions? |
#2 |
It's just a power amp, all you need to do is build a guitar preamp to feed it.
It's less power because it's higher quality, guitar amps sacrifice quality for power, because you don't want quality in a valve guitar amp. If the transformers are big enough, reducing the value of R11 and replacing R12 with a suitable choke, should increase it's power capabilities.
Nigel Goodwin |
#3 |
Good stuff, Nigel. Is there a guitar amp circuit you prefer that i could work off of? I'm not at a "roll my own" level at this point.
#4 |
#5 |
I'd eBay it as folks are always looking for Leslie repair parts. There are even folks building new replacements!
Then with the proceeds you can buy parts more in line with a guitar amp. |
#6 |
Yes, I'd suggest you could easily leave out one of the stages.
Nigel Goodwin |
#7 | |
I've got a lot of amps anyways... '68 Fender Super Reverb, '68 Vibro Champ, '67 Silvertone 1484, '65 Danelectro DM25, '73 Ampeg VT40, '78 Ampeg B15N, '71 Plush 1060C (bassman 100)..... I'm not doing this because i need a guitar amp so much as i want to do it because it's a fun project. |
#8 |
The Leslie looks like it uses half of a 12au7 as a Phaze splitter but the other half is un-used , You could wire up the other half of the 12au7 as a gain stage , it wouldn"t have a whole lot of gain but if you changed the 12au7 to a 12ax7 you would get a bit more gain out of it .....
You could also just leave the 12au7 as it is and wire in a seperate 12ax7 and get a lot more gain and add a tone stack between the 2 12ax7 stages , the only problem I could forsee is maybe not having enough Heater current for the 12ax7 ..... Cheers |
#9 | |
Of course there are those that would turn a restored 1937 Bugatti 57 into a planter! They would then have the only one. |
#10 |
You don't have a 57 Bassman, shame on you. Not that I am suggesting anything.
I would add two 9 pin sockets and redo the phase inverter as a LTP. Leave the cathode bias for now and convert it after you get the rest up and running. http://ampwares.com/schematics/bassman_5f6a.pdf The low wattage using 6L6's is probably due to the selection of the output and maybe even the power transformers. I have a Bogan amp with 6L6's that is also rated at 20W. The power transformer is big enough for a higher power amp but the OP transformer is the limiting factor. |
| Rewiring headphone speakers to amp | m500sesp | Headphone Systems | 0 | 25th August 2011 12:33 PM |
| Tube amp / Leslie speakers | Leslie Hammond | Instruments and Amps | 9 | 25th July 2011 10:59 PM |
| Help with several issues please: rewiring, blown B&K AVR507 updated to version 3, etc | paulieg888 | Solid State | 1 | 26th June 2011 03:58 PM |
| M&K V-125 schematic or help | quadzilla | Subwoofers | 0 | 9th July 2010 11:34 PM |
| how to model 125-0-125 in PSUD | cbutterworth | Parts | 2 | 3rd November 2006 03:47 PM |
| Page generated in 0.12907 seconds (77.77% PHP - 22.23% MySQL) with 11 queries |
