Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st December 2011, 12:09 PM   #1
gcb34 is offline gcb34  United States
Default Ampeg B500DR bass head solid state
First off thanks for any help you can offer. I have a Ampeg B500DR bass amp that won't get put out any bass guitar sound. When I turn up the volume the fuzz gets louder but no signal output. There is a relay I was tapping on and after a few taps I resistor in the power section fried. I attached the block diagram but could really use the schematics if anyone out there has them.
Old 1st December 2011, 06:27 PM   #2
indianajo's Avatar
What does the DVM (volt-ohmmeter) say the speaker leads read on the low ohms scale? Should be 4 ohms or above. Calibrate the meter with a known resistor, when meter batteries go weak this is the first scale to read the wrong numbers.
If that is okay, how old is the amp? Does it have IC's on the heat sink or Transistors. How old are the electrolytic capacitors? (25 years is too long).
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 3rd December 2011, 01:28 PM   #3
Transistors on the heat sink the unit is 18 y.o.
Old 3rd December 2011, 06:15 PM   #4
indianajo's Avatar
Well, if your speaker or wires are not messed up, (test above) check to see if there is DC coming out of the speaker hot terminal on and idle. If so, one or more output transitors are bad. Then if none of that, check your power supplies that they are about 80% of the capacitor rail voltage. Checking rail voltage while playing into 4 ohm resistor (watt rating >amp rating) would be a better test.
Old 3rd December 2011, 09:58 PM   #5
The speaker and wires are good. The weird thing is when you turn up the volume you can here it increase but nothing from the bass guitar comes out.
Old 3rd December 2011, 10:29 PM   #6
I plugged a preamp in the poweramp input and did get sound.
Old 4th December 2011, 08:11 PM   #7
indianajo's Avatar
If you take any of the measurements I suggested, I will comment about the results.
solid-state Bass amp lotus Instruments and Amps 10 18th May 2009 02:06 AM
Solid state bass guitar amplifier shematics kellmik Instruments and Amps 4 8th May 2006 07:59 PM
200-300w solid state bass amp plans? motocross_mike Instruments and Amps 23 30th January 2006 11:02 AM
Page generated in 0.08579 seconds (73.94% PHP - 26.06% MySQL) with 11 queries
