Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st December 2011, 05:49 AM   #11
ArcticBreaze's Avatar
the main reason the mic dosnt work to well for me is a lack of co-operation from other muso's, ie stick my mic in front of ma wee 5e3, then a guitarist cranks up a hot rod deville right next to it at 3 times my max output and all I'm micking now is a dmn guitar lol. so this way no interferance from other instraments but dont let me rant on i'll try this and let ya know how it works next jam is on the 17th.
Old 1st December 2011, 06:08 AM   #12
ChrisA is offline ChrisA  United States
Originally Posted by ArcticBreaze View Post
the main reason the mic dosnt work to well for me is a lack of co-operation from other muso's, ie stick my mic in front of ma wee 5e3, then a guitarist cranks up a hot rod deville right next to it...
You missed the part about using an isolation box. This is a big sound proof box and in side it goes your amp (or speaker cab) and the microphone. The entire assembly can be in some back room, off stage
Some times the box rather then having your entire speaker cab inside has only part of one, the front baffle and the speaker,
Box is typically dual wall plywood with sound absorbing foam or fiberglass batting between the plywood sheets
So it don't matter if some other guy plays loud there is sound proofing between him and your mic.
This will give you the idea
VB Guitar Speaker Box
Old 1st December 2011, 08:29 AM   #13
jazbo8's Avatar
whats the best way to put a line lvel out put on my fender delux 5e3 clone want to get as close to its sound out put as posabile (Ie that over driven power stage sound) so i can di thru a pa.the amp sounds great its just not loud enough to play with a full band.
Try London Power's Power Scaling or Dana Hall's VVR. Then just connect from the speaker to your PA/monitor feed via a resistor. The scaled output will give you the full crank sound but you still need to rely on the PA to sound big...
Jaz
Old 1st December 2011, 10:17 PM   #14
K i see what ya mean about the cabnit. will build one of these too ansd try both ways cheers guys
Old 17th December 2011, 09:45 AM   #15
ok guys my verdict is in....the speaker lvl DI is the way to go my amp sounds fantasic thru front of house still got that overdrin valve sound, had to take sum treble outa th pa then it sound just the same as my amp. it ways nothing and sits inside the amp case.so its not just even more gear to lug round. Im sold.
Valve Line Amp - Borbely EB894/211 Clone Andy5112405 Swap Meet 9 27th May 2011 11:21 AM
6SL7 5E3 - together at last? atmars Tubes / Valves 12 24th November 2008 01:59 AM
5E3 chassis Colinsky Everything Else 0 23rd July 2008 10:10 AM
Clone Marantz M7 Line Amp kmtang Tubes / Valves 6 29th October 2005 05:53 AM
Dipole/Open Baffle: To go line array or Orion clone? Chaucer Multi-Way 3 1st July 2005 06:35 PM
Copyright Đ1999-2013 diyAudio
