| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I really can't get my head around this. What is what?
#2 |
One input is for high output pick ups (the top one) and the other is for low output types I believe. The schematic is not complete so there may be even more going on.
www.kta-hifi.net |
#3 |
Looks like a Fender? If you mean the 1000pF cap, yeah, that is strange.
All good fortune, Chris |
#4 |
I mean how does it get wired? what is the tip what is the sleeve and so on.
#5 | |
I'm not going to try with those drawings..
www.kta-hifi.net |
#6 |
"I'm not going to try with those drawings.. "
WOW! Thanks |
#7 |
the tip reaches in farthest. It contacts the switch at the farthest end from the facia nut.
The sleeve reaches in the least and contacts the shortest switch. When looking at the back of the socket you should be able to see the mechanical arrangement and from the 3 solder tags work out which is tip and which is sleeve. Similarly when looking at the back of the plug, you can identify the Tip, Ring & Sleeve solder tags. And yes, a resistance meter will show instantly which tag connects to which switch. Can't get inside the socket !! Insert a plug for unrestricted access. BTW, a Buzzer on low ohms is very handy for this.
regards Andrew T. |
#8 |
The jacks you are showing are not quite right. The picture shows stereo jacks with a switch on tip and ring. The schematic is showing a mono jack with isolated switch, probably just using the switac to mute the pre-amp out when nothing is plugged in. Those two switches are wired in series from ground and the wire off the lower switch would go to the pre-amp output to mute it.
#9 |
It looks like the input jacks are wired to accept a normal mono wired guitar through the tube shown, and rout a stereo wired guitar through the tube shown, and through the path not shown. It is not totally clear just what happens with two guitars when one is stereo wired and one isn't.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#10 |
It has nothing to do with a stereo wired guitar, though a pair of 1/4 males would work in the jacks. It is just two inputs, one being more sensitive than the other.
magicsamin is correct, the pictures of the jacks they used are not the type the schematic calls for. The pictures are for "stereo" jacks, more commonly called TRS (Tip-Ring-Sleeve) jacks. The schematic calls for "mono" jacks with extra cutout contacts. The tip of the plug is the tip, easy enough. And the sleeve refers to the shaft of the plug. In stereo plugs like headphones use, there is an extra band just behind the tip. That is called the ring, hence tip-ring-sleeve. A plain old guitar cord plug - mono - would be called a tip-sleeve. Ignoring the extra contacts for a moment, this is classic Fender input jack wiring. Each jack shows two sets of contacts. The upper set is the tip contact, which touches the plug tip. There is also a cutout contact bearing on that, so when you plug in, it opens that set of contacts. The lower set on each is what we will ignore for now. WHen you plug into jack #1, the lower of the two, the contacts on the tip of jack #2 put the two 68k resistors in parallel, so 34k. The 34k is in series with the guitar signal and the grid of the tube, a grid stopper if you will.. However, if you plug into jack #2, then the signal hits the 68k to the grid, but the other 68k winds up from that grid to ground, soo there are two 68k now in series across the signal, with the center point to the grid. This forms a 2/1 voltage divider, cutting the signal voltage in half, a 6db reduction. SO jack #2 is lower in sensitivity. You usually use jack #1 unless the guitar signal is too hot, then use #2. Look up the schematic for an old 5E3 Deluxe or maybe a Twin Reverb, and you can see the same wiring without the extra contacts, might be more clear. And the other extra contacts? The contact in the upper jack is grounded, then the line runs through the second jack and off into the amp somewhere. So that mystery line is grounded until either jack is in use, otherwise it remains grounded. All that is, is a mute. It grounds off the signal path when nothing is plugged in to reduce unwanted noises. |
| Can you explain what this is ? | istari knight | Tubes / Valves | 12 | 15th May 2010 06:17 PM |
| Please explain what I did | amo | Solid State | 22 | 16th July 2008 12:56 PM |
| can please someone explain this to me? | krusty75 | Tubes / Valves | 6 | 18th February 2008 09:38 AM |
| Can someone explain to me? | MaXiZ | Solid State | 3 | 12th November 2003 09:36 PM |
| Can someone explain to me this? | MaXiZ | Solid State | 17 | 1st October 2003 06:43 AM |
| Page generated in 0.13349 seconds (78.92% PHP - 21.08% MySQL) with 11 queries |
