| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I'm looking for a 59 Bassman or rebuild.
Anyone have the original? What is the cabinet type? Is it a ported or closed box design? Some are a single 15", others are 4x10". The original circuit was reportedly the best and most responsive, but no schematics were drawn for it. |
#2 | |
The original TV front I have nothing on, The Wide Panel 1 X 15 Schematic Bassman 5B6 Layout 5B6 By far the most popular Bassman was the 1959 5F6-A Schematic & Layout Last edited by Trout; 11th November 2011 at 02:30 AM. |
#3 |
I have a 59 bassman, it is the one you speak of with 4x10" speakers and the 5F6-A layout. Looks kind of like a marshall on paper with a cathode follower driving the tone stack. I was thinking about doing a cap job and replace the selenium rectifier for the bias supply. And maybe add a modern grounded power cable. Oh and the cabinet is an open back design.
#4 |
Yes thats the one using Eminence woofers.
Do they go down to the open E string on the bass? That would be around 41.5 Hz. |
| Fender Bassman Ten | Benny Bennett | Instruments and Amps | 2 | 2nd April 2009 01:01 PM |
| Fender Bassman PT Rewind | OKBill | Tubes / Valves | 4 | 14th January 2007 02:51 PM |
| Modifing A Fender Bassman Scheme | amirmk | Tubes / Valves | 5 | 16th September 2005 07:34 PM |
| c25 cap in '59 Bassman ReIssue | otokomae | Instruments and Amps | 4 | 13th September 2005 03:14 AM |
| Help! Q? about Ohm load in '59 Bassman RI | otokomae | Tubes / Valves | 2 | 19th August 2005 06:42 AM |
