Output transformer for 18watt - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th November 2011, 08:36 PM   #1
Default Output transformer for 18watt
Hi. Im building my third amp. An 18 watt clone, based on the layout from ceriatone:
http://ceriatone.com/images/layoutPi...Wceriatone.jpg
The OT wires on the layout are blue, red and brown! The blue and brown wires goes to the powertubes, and the red one goes to the big cap.
Well, My OT has brown, red and white wires? (IGOT-M18R)
The brown is B+ according to the datasheet, and the red and white are anodes?
My guess is that Im supposed to solder the brown wire to the cap, and the two anodes to the powertubes.
But the colours have me a bit bit confused, and the technology og the output transformer in apparantly a bit out of my league?
Can anyone point me in the right direction?
Thanks in advance
-Kasper
Old 8th November 2011, 08:51 PM   #2
Send a message via AIM to DigitalJunkie
Your guess is correct. Follow the OT datasheet. Brown to B+ and Red/White to the anodes.
Old 8th November 2011, 08:52 PM   #3
Thanks a lot
Old 8th November 2011, 08:54 PM   #4
firechief's Avatar
Where did you buy the transformer? Can you direct us to the data sheet?. I would not guess the same as you, in fact I would assume that the red was still the center tap of the primary of the output transformer and therefore should go to the cap. If you have an ohmeter you should be able to measure the transformer primary and at least decide which is the center tap. This could be be kind exciting if you get it wrong. If you get the two other wires on the wrong tube it will not go boom, so you need to find the center tap.
Also Ceriatone does not provide schematics which is I believe a busness decision. A very good learning assignment for you would be to sit down and draw the schematic from the layout. Or perhaps someone else has it posted online.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 8th November 2011, 08:55 PM   #5
firechief's Avatar
Digital Junkie you sure?
Old 8th November 2011, 08:59 PM   #6
If that's what the datasheet for the output transformer states,that's what I'd go with. Double check the DC resistance with a DMM to make sure.
Old 8th November 2011, 09:00 PM   #7
Well i bought it from
http://www.tube-town.net/ttstore/product_info.php/language/en/info/p5013_IGPW-Marshall--18-Watt-Ausgangsuebertrager.html
The sad thing is that I cant seem to find a datasheet on the internet. But the Trafo came with a piece of paper that explained the wires, as described in my first post.
The brown is in the center of the diagram primary winding, and is called "B+". The red and white are the two "outer" wires in the diagram, and they are called anodes.
Old 8th November 2011, 09:01 PM   #8
I have an ohmmeter by the way. What do I measure? Hate being such a beginner at this
Old 8th November 2011, 09:22 PM   #9
firechief's Avatar
Set to ohms. This is going to be very low resistance so just clip the leads together and make note of how close your meter reads to zero ohms. Most of the time it will be like a couple of ohms because of the lead resistance. Then go between any two of the primary leads. The resistance between the center tap and either of the two outside leads should be 1/2 of the resistance between the two outside leads. Does that make sence?
Old 8th November 2011, 09:29 PM   #10
It makes perfectly sense
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Copyright 1999-2017 diyAudio
