Hall VVR in an AC4TV - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd February 2012, 07:30 AM   #11
@clengman: I am going to make the same mod on my 4TV. Very interesting topic with very useful informations.
Anyway, did you finally modify your amp? Does it work fine?
Old 3rd February 2012, 01:43 PM   #12
Vincenz - I sent a PM, but I remembered that I didn't end up doing the mod exactly as Nigel recommended. I think my method is equivalent though. You can see what I did with pics here:
http://www.sewatt.com/node/19662
I think you need to register an account to look at content there.
Old 7th February 2012, 05:01 PM   #13
Vincenz - since you said you were having a little trouble registering on sewatt.com, here's a pic of the mod the way I did it, and what I posted on the forum:
I've attached a photo of the front of the board for reference and a photo of the back of the board that's marked up with my proposed installation. This is what I'm planning to do:
1) Remove the jumper that connects Tag 6 to the trace connecting the diodes, the first filter cap, and R16.
2) Make a cut in the trace at the white line just above the diodes.
3) Connect a jumper (red line) from R16 to "Tag 6."
This should divide what was previously one node (the diode output/OT input trace) into two separate nodes for B+ OUT and B+ IN as I have them marked in my photo. It also leaves two vacant holes in the PCB that can be used to solder in the VVR.
It's working fine.
Old 7th February 2012, 07:42 PM   #14
Thanks for these informations ! I will try this asap
Any Hall Effect gurus out there? peace brainerd Everything Else 39 7th April 2013 11:26 AM
fikham hall cookie monster Everything Else 0 30th July 2010 05:34 PM
subwoofer for party hall space2000 Subwoofers 5 29th May 2008 07:03 AM
Music Hall CD25 help. robertwstephens Digital Source 1 29th April 2007 05:23 AM
Music Hall Maven Help.... TikiGod Solid State 1 10th October 2006 03:05 AM
Copyright 1999-2017 diyAudio
