Switchable Hi-Z input impedance, how ? - Page 9 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th December 2011, 02:52 PM   #81
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Nigel Goodwin View Post
Some people (yourself included) seem to like the lower qualty sound that valves give you, there's no accounting for taste..
Nigel, you draw too fast conclusions
Old 14th December 2011, 03:10 PM   #82
Originally Posted by tinitus View Post
Nigel, please notice I said bass guitar only
not quite the same thing as guitar
I was referring only to bass, although the exact same thing applies to guitar as well.
Nigel Goodwin
Old 14th December 2011, 03:14 PM   #83
Hardly, as you've been discussing valves throughout this thread, and endless weird configurations of valves and FET's.
Presumably you're looking for lower quality sound for a bass?.
Nigel Goodwin
Old 14th December 2011, 05:17 PM   #84
depends what you mean by quality
distortion seem to be a key element of good quality guitar sound
but the question is, how to differ between low quality and high quality distortion
and the difference really is there, we know that
but its still distortion
and often exstreme
Old 14th December 2011, 08:35 PM   #85
Except we're talking bass, not guitar - remember?
and often exstreme
There's no such thing as 'quality' distortion, by definition it lowers quality. Some guitarists want distortion for some styles of playing, I've no problem with that at all, in fact I'm all for it - heavy metal would be a sad thing wihout it
But it's far rarer for bass, not many want distorted bass, even the heavy metal crowd.
Nigel Goodwin
Old 14th December 2011, 08:46 PM   #86
thats my point
bass guitar needs only small amounts of distortion
and not really audible when playing with others
a very different from what a guitarist needs
non distorted is really not a possible option, is it ?
Old 15th December 2011, 02:16 PM   #87
thats my point
No, it's needs none at all, unless you're aiming for some specific effect?.
Distortion well below the range of hearing is easily possible, and most bass amps provide that.
Nigel Goodwin
Old 15th December 2011, 04:44 PM   #88
what instrument are you playing
Old 15th December 2011, 06:39 PM   #89
ahhh
found this on Alan Kimmel site
Because most MOSFETs are enhancement-mode types and cannot be self biased, we must supply fixed bias to it. This does not compromise the performance in any way. We want the MOSFET's source terminal lobe at about half the B+; therefore, our fxed bias must also be half the B+. We can derive this bias voltage by using a simple voltage divider of two equal-value (say, 220k)) resistors in series. Connect one end of the voltage divider to B+ and the other end to ground with a 1-5uF capacitor across the lower resistor.
The junction of the two resistors will be the fixed bias supply point to which gate resistor Rg2 will he connected. This simple arrangement has given excellent results. However, if you do not want a voltage divider, you can use a zener string for Q1's fixed bias voltage source. Operate zeners at about 20% of their maximum current rating and use a 10uF capacitor to bypass the zener string. If you build a stereo pair or a push/pull pair of Mu Stages, the same voltage divider (or zener string) can serve both. No interaction will result.
Old 15th December 2011, 09:04 PM   #90
I don't play anything, but my daughter plays bass, piano, keyboards, flute, guitar, piano accordian, drums, and she sings - and has gigged on them all.
I just do the PA
I've seen, used, and repaired MANY bass amps and combos, they don't add distortion.
Often we just DI the bass directly in to the PA, no on-stage monitors either.
Nigel Goodwin
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
