Switchable Hi-Z input impedance, how ? - Page 65 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 23rd July 2013, 10:03 PM   #641
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Nigel Goodwin View Post
Nothing 'unsafe' about it - no way it possibly could be.
no, I guess not...if you like the sound when the jack falls out at full blast
Old 24th July 2013, 09:02 AM   #642
use a locking XLR.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th July 2013, 10:10 AM   #643
locking XLR on a guitar ...
actually, Neutrik makes locking jack plugs too, but for amps or speakers....not for guitar
but with better quality plugs the jack does not come loose so easily
gosh...
Old 24th July 2013, 10:17 AM   #644
Still not 'unsafe' - and you only get a very brief 'blip' as it falls out anyway - but I can't say I've ever seen a guitar where the lead easily falls out?.
As AndrewT said, replacing the jack with a locking XLR would 'cure' it, but perhaps improving your playing style might be all that's needed?.
Nigel Goodwin
Old 24th July 2013, 10:23 AM   #645
Most stage performers are already familiar with locking XLR on their microphones.
Why accept a lesser standard on other portable equipment?
That's a question to anyone that can explain the existence of " trs, other than being "cheap skate".
regards Andrew T.
Old 24th July 2013, 11:30 AM   #646
a natural development of 1/4" jacks used on telephonepatch panels - ideal for a large horizontal "in your face" switching matrix.
Old 24th July 2013, 12:32 PM   #647
Why spend extra on an expensive connector when a cheaper one is perfectly satisfactory? - and 1/4 inch jacks were used on mikes for many years as well.
As you don't need a balanced connector on a guitar, that's another reason not to use an XLR.
Reverting to the previous 'unsafe' comments, a locking XLR on a guitar is probably far MORE 'unsafe' than a jack - where a jack plug will pull out if excessively strained, a locking XLR won't, perhaps making you fall over, or pulling heavy equipment on top of you (both far more unsafe than the jack harmlessly falling on the floor).
Nigel Goodwin
Old 24th July 2013, 01:37 PM   #648
shanx is offline shanx  Canada
Neutrik makes locking 1/4'' jacks as well.
One place where I really don't like standard 1/4'' jacks is on amp's speaker connection. That or banana plugs on PA systems. That is potentially dangerous. Neutrik Speakon connectors with twist locking are very good, fast to set up and better connection.
Old 24th July 2013, 05:11 PM   #649
Passinwind's Avatar
If you have an active instrument with the standard power switching scheme the full battery voltage hits the tip as the plug comes out and the tip contacts the middle connection on the jack. That can and will blow drivers in some cases, and definitely sounds horrendous IME.
-- Charlie Escher
Old 24th July 2013, 09:01 PM   #650
Originally Posted by Passinwind View Post
.... That can and will blow drivers in some cases, and definitely sounds horrendous IME.
thank you
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
