Switchable Hi-Z input impedance, how ?
Ex-Moderator R.I.P.
Joined 2005
decided I wanted a new front
Ex-Moderator R.I.P.
Joined 2005
now testing this 'tone curcuit' on different basses
this is simpler, and better
cleaner, and tighter
and somehow results in better harmonics
also, instrument is easier to tune
tested on two basses, and result is more or less the same
it is 100% clear now that a tone control also affects tuning
and could be quite a lot really, and even involve the bridge
so, if anyone have a bass that is 'difficult' to tune, it might very well be caused by the tone control
Ex-Moderator R.I.P.
Joined 2005
and this is the final result of the tests
best allround tone of all I have tried yet
at least for my speaker it is
typically I use caps from 15n to 33n
series resistor varies from 1k to 3k
parallel resistor on pot is typically around 22k
small variations depends on each instrument
Ex-Moderator R.I.P.
Joined 2005
anyway, I found out why the truss rod never functioned properly
a big lump of glue was in the way, and the nut was missing 5mm to be positioned correctly :eek:
seems they forgot to screw the nut fully in before mounting fretboard :mad:
I always feared the truss rod was faulty
but expect it will be ok now, at least :)
