Switchable Hi-Z input impedance, how ? - Page 61 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th June 2013, 08:59 PM   #601
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by shanx View Post
Get some copper tape and line the insides, as well as the cover, and connect to your jack ground.
yes, I have seen pictures of that
strangely its 100% hum free right now
both pots are connected with a wire soldered dirctly on housing
and there is a tin foil on pickguard/cover, connecting to jack plug ground
but I have a little very mild 'white noise/hiss' that might be related to interference
btw, almost all the noise I had before dissappeared when I left the 2 channel setup, and connected only one channel
funny thing
ground from unused channel on 2-channel power amp have to be connected to preamp ground
it connects to a free RCA on preamp, only connected to ground
Old 26th June 2013, 09:47 PM   #602
shanx is offline shanx  Canada
From your previous pic I think you have shielded pickup cable, which will help in reducing interference. Yes if you leave one channel of power amp floating open you could get that problem.
If you terminate it's ground to the same point in your preamp, you may have removed a ground loop there.
After I built my guitar preamp, a friend who plays bass asked me to build him something similar.
He plugs in to mixing board and with a passive bass, not enough volume etc..He normally uses a multi effects pedal (commercial, I won't say which), but the sound is noisy and not a lot of output level. So I am thinking a simple fet pre, active tone/eq and unbalanced/balanced line out. Wonder if I should suggest to put an effects loop in there?
Old 26th June 2013, 10:45 PM   #603
not sure
many effect pedals power on by plugging in the input jack connector
in the effect loop they would be permantly connected, and burn the battery
in such case it might be better to just have two input
with input selector switch
one input for pedals, and one straight
or have I overlooked something ?
Old 27th June 2013, 03:31 AM   #604
I was just thinking out loud and wondering if it was worth adding it. Could always put it in later. Even the balanced output adds a few parts, need a +/- supply so don't want it to cost too much.
Are you planning on doing the tube section of your preamp? Sounds like you were happy with the fet.
Old 27th June 2013, 08:44 AM   #605
yes and yes
waiting for my new bass ... very happy with my 28" kids bass, but time to try a full(long) scale
Old 27th June 2013, 01:29 PM   #606
Cool! Let us know when you get going on it. And for a new bass that is always fun. What type (just curious)
Old 27th June 2013, 02:20 PM   #607
its a Cort Action Passive 4 Red
cost 200EUR
I liked it right away
easier to play than my short scale
which is a surprice
Old 28th June 2013, 07:57 AM   #608
AndrewT is online now AndrewT  Scotland
Can you explain the two sets of pickups?
And why one set is split into staggered sections?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th June 2013, 08:40 AM   #609
its just ordinary Fender type P-style and J-style pickups
and I suppose it stands for Precisson Bass and Jazz Bass
the two famous Fender models
but this appears to be a silly slapbass
and just I hate slapbass
it all sounds the same to me
it has a pronounced metallick string noise
but since its a slapbass I suppose it meant to
maybe I will be able to 'repair' it
other strings could be needed as well
or I can just keep it as is
not sure what to think about this
for the money it is nicely designed and well built
I especially like the neck with wide string spacing
and it does have this charming chrispy gnarly slapbass sound
quite impressive they are able to do this
I guess its just nice to have as 'optional bass'
its cheap enough for sure
Old 28th June 2013, 09:29 AM   #610
Precision & Jazz bass,
is that different harmonic content?
Why the two sets and why are they different positions?
Why are one set split?
regards Andrew T.
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
