Switchable Hi-Z input impedance, how ? - Page 60 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th June 2013, 01:30 AM   #591
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by shanx View Post
Anyways I hope you keep experimenting and have fun!
status quo of my big power amp project
Old 13th June 2013, 01:22 PM   #592
shanx is offline shanx  Canada
Glad your enjoying the preamp as it is, simple is good. Now for that power amp project of yours,
those heatsinks look like it's ready to put out some serious wattage. Do you have that build going on another thread?
Old 13th June 2013, 03:25 PM   #593
no, not yet
but its from apexaudio's '1000watt Simple PA Amplifier'
well, I really dont need it, but since I already got most parts, why not try it
besides, it might be fun to have such a power monster
Old 13th June 2013, 03:54 PM   #594
Yes that is some serious wattage there!! Good luck with it. Maybe you will post the build online?
Old 13th June 2013, 04:11 PM   #595
Good luck with it.
I may need it, thanks
yeah, I suppose there will be more to post later
Old 20th June 2013, 08:43 AM   #596
sure hope it will work again, later
need to search a bit on this stuff
Old 20th June 2013, 08:10 PM   #597
Hi Tin, I actually thought you mounting your fet preamp into your bass to make it active. But saw from your other post that it is some pickup rewiring.
Old 21st June 2013, 09:10 PM   #598
sorry, I got busy, and was confusing
broke one coil wire, but managed to fix it, and it works ok again, in parallel
nah, I hate batteries, and prefer passive
Old 23rd June 2013, 10:36 AM   #599
like said, it works fine again
and I like the parallel pickups too
but had to change tone control cap
or else it was way too bright
found a wire had been jammed by magnet
and I broke one coil wire
I suppose it burned from too many solderings, when testing the different configurations
not all worked well
(as a warning if you try this)
Old 26th June 2013, 04:39 PM   #600
Hi Tinitus, yes those really small wires can be tricky. I avoid touching them if at all possible. If I do I rewire the other end of the cable connections with a switch. In my case it's a 5 way switch for strat style 3 pup. While you have the pickups out you may want to look at the shielding inside the cavity of the bass. Get some copper tape and line the insides, as well as the cover, and connect to your jack ground. Should be a big improvement to reducing hum and interference.
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
