Switchable Hi-Z input impedance, how ? - Page 52 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th April 2013, 10:20 PM   #511
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
or slightly simpler
Old 19th April 2013, 09:42 AM   #512
managed to 'arrange' caps between att pot and buffer
and it works...humm is now gone
only a modest snerring coming from instrument remains yet to be fixed
oh, btw, completely forgot about it
was hoping it would also be a good home for simple 12db line out crossover
thanks for your patience
cheers
Old 20th April 2013, 06:27 AM   #513
removing collector resistor....oh horror
endless distortion....no matter what I did
spent half a day changing resistors, with no result
remounting collector resistor....no other changes, worked right away
Old 20th April 2013, 07:23 AM   #514
Originally Posted by tinitus View Post
or slightly simpler
why does "slightly simpler" need three attenuators?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th April 2013, 10:08 AM   #515
Each with un-needed extra resistors all round them?.
Although I think the idea of the multiple pots is a master volume, and separate output volumes on the two output channels.
But the main problem is trying to design a circuit knowing next to nothing about electronics, and essentially just 'guessing' configurations and values.
FET, master volume, single buffer transistor, two output pots (4.7K off that buffer) - job done).
Nigel Goodwin
Old 20th April 2013, 10:47 AM   #516
one controls gain
one controls a woofer
one controls mid/tweeter
buying active xo would automaticly give me the two output attenuators
or a 2-channel PA power amp
one single jfet, and done.....
and I will probably try that too
just to experience how it works
Old 21st April 2013, 11:56 AM   #517
measured voltage drop(s)
Old 21st April 2013, 11:59 AM   #518
shanx is offline shanx  Canada
Hi Tinitus, I figure that with 2 jfet stages preceding instead of one, that you had quite a bit of signal gain going on. On the emitter follower buffer did you stay with 830 ohm when making changes? Nigel also suggested putting the two attenuators after the emitter follower, with just master volume at the preamp. That is the ideal spot. As I mentioned earlier, the e-follower has or should have enough current drive to handle your loading of filter circuits, attenuators etc..
Build active xo: just suggestion, but it's only two way xover so not too hard with opamps. you already have power supply, box hardware and buffered preamp, maybe $10 of parts for a simple one.
If you are thinking of running your preamplifier to a mixer board or any professional PA power amp, strongly suggest balanced line out XLR. Use DRV line driver chip to do this. Major advantage is you greatly diminish chances of introducing ground loop hum from equipment on different ac power circuits.
Hope you have fun!
Old 21st April 2013, 12:16 PM   #519
Originally Posted by shanx View Post
active xo..... maybe $10 of parts for a simple one.
....balanced line out XLR. Use DRV line driver chip to do this.
Hope you have fun!
balanced line out would be good for PA poweramp
it was my hope to try build a chip amp
just for a tweeter, with integrated active xo
Hope you have fun!
when it works thanks
btw, I have a single jfet Hi-Z preamp, with no attenuator
even driving my poweramp(s) directly, it had way too much gain
might work ok, now that I have a buffer with output control
Old 22nd April 2013, 03:17 AM   #520
There have been many people posting the instrument/amps section, looking to do the preamp/chipamp combination. If you are also looking at that option (for home practice etc), go for it. IMHO most of the characteristic sound of that combination should come from a really well built preamp section, and the chipamp role being to give a neutral amplification of the preamp sound. There are a few parameters that could be manipulated at the chip amp section, but if you are also sending the preamp signal to a mixing board or PA, I presume you will want to have similar sound there as well.
A lot of commercial small practice amps and even larger SS amps are now using chipamps as the power section, but I find they are completely lacking a lot of potential in the preamp section, so I hope working on the pre you get that sound you are after.
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
