Switchable Hi-Z input impedance, how ? - Page 48 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th March 2013, 08:38 AM   #471
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
this variations sounds 'promising'... different... and feet tickling
Old 23rd March 2013, 08:48 PM   #472
this version is better, and works ok, for the moment
Old 7th April 2013, 12:19 PM   #473
shanx is offline shanx  Canada
Hi tinitus, looking at the blend balance control and wondering if you consider to add some signal filtering at that stage? Maybe look at rolling off some of the real low frequency to the mid tweeter stage, and cutting some high freq to woofer stage. Not sure if you plan to have EQ past the first two or not, so just suggestion..
Old 7th April 2013, 01:44 PM   #474
hello shanx
been quite happy playing though the latest shown version
but removing a hifi preamp/buffer for other purpos have shown that its time to work on that buffer output
I am now driving my poweramps directly with just a single jfet boz
no gain control or any other att
only the bass guitar onboard att pot
the gain is excessive I can barely touch it..its pretty exstreme
and its only with passive pickups
needless to say, a bit noisy too
so Im now working on a simple BJT buffer with a single BC547
just to try it
looking at another alternative 'angle'
it also shows that I can easily drive a 3way active crossover with a simple jfet
hopefully soon will work on the curcuits I got from Juma
Old 7th April 2013, 07:46 PM   #475
just to try it
wow, I have a working power supply
Old 8th April 2013, 02:28 AM   #476
I am glad you like playing through it. Sometimes better to have without tone circuit, depending on your preference of course. I am still working on my jfet preamp, and agree that for bass you could easily overdrive the stages..but which for guitar is not necessarily a bad thing! But I am still trying some simple tone shaping methods with interesting results. Good luck on the BJT build and keep us posted.
Old 12th April 2013, 04:08 PM   #477
it works but distorted
I suppose bias is too low
Old 13th April 2013, 06:38 AM   #478
but was expected....
could it be too low base turn-on voltage
and maybe I need to 'isolate' the input att pot
on the positive side...noise is much lower with the buffer
Old 13th April 2013, 12:55 PM   #479
small adjustments
and now with 100K 'pots'
wow, what a change
no audible distortion
straight clean sound
plays fast
but now I got a little trafo humm in the speakers
Old 14th April 2013, 07:19 PM   #480
humm is annoying
trying a 4mH air core
takes the snerring
but there still a very deep humm
next project
a 'rail splitter'
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
