Switchable Hi-Z input impedance, how ? - Page 47 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 4th March 2013, 06:31 PM   #461
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Nigel Goodwin View Post
It has no effect at all - it's purely imaginary
its funny, but every time you have said that, I have tested it, just to see if you could be right
but no, I have to disappoint you and say; it does make a small difference
with balance turned towards the bass output connected to the woofer amp, I get a bit more forward low bass
and at the same time the upper register turns slight dry, with the pitch going down a just bit on the sustain
not easily heard, but the change is there, 100%
turning balance pot the other way, towardsmid/tweeter output, connected to ....the pitch stays up with more prolonged sustain
at the same time the low bass seems to get a bit more smooth and soft, with less attack
small changes
but you know how these small things matter when playing the finer tunes
btw, increasing the series resistor after attenuation pot to 470ohm made it slightly brighter, and more airy
Old 4th March 2013, 07:20 PM   #462
Sorry, I don't believe you, the difference is absolutely too small to measure, never mind hear.
You're not helping your cause by using imaginary meaningless terms like 'forward' and 'dry' either.
small changes
More imaginary terms
Why not just wire the pan pot correctly - just add four resistors (or just the first two would do) - with your 4.7K pot, drop the 3.3K resistors to 1.5K or 1.8K, this would then give you a proper working pan pot.
Consult the circuit attached.
Nigel Goodwin
Old 4th March 2013, 07:57 PM   #463
Sorry, I don't believe you.....
no, thats very clear, but thas fine with me
I know it works as described
but with a distorted guitar its not likely to work
You're not helping your cause .....
actually, it works so nice that I still consider something similar in my next preamp, but with a 5 position rotary switch instead
and ofcourse combined with additional seperate channel attenuators
Old 4th March 2013, 08:03 PM   #464
Why not just wire the pan pot correctly....
pan pot ?
as I understand it, a pan pot feeds part of a 'foreign' signal from one channel to opposite channel
would be more a blend or mixing thing, and the opposite of splitting a signal, is it not ?
Old 4th March 2013, 08:17 PM   #465
ok, I se your 'pan pot' version now
signal feed to each 'side' of the pot, and wiper is 'ground control'
ground control calling...he
that seem fairly easy to try without making too much mess
thanks Nigel, I might give it try
Old 4th March 2013, 08:22 PM   #466
and maybe change attenuator to a stereo pot
one of those with seperated concentric shaft would be nice
they are not easy to find, but I have seen one for guitar use
Old 4th March 2013, 08:32 PM   #467
hey, with a linear stereo att/pot, there might be a fun option
using different paralel resistors for each channel, could result in a interesting function
I think you would call it 'having different law' for each channel
with a switch..
Old 4th March 2013, 10:20 PM   #468
and the crazy idea....linear stereo att pot with variable law/log
Old 5th March 2013, 07:59 AM   #469
'Crazy' as in you've altered it at random to stop it working.
Nigel Goodwin
Old 5th March 2013, 09:12 AM   #470
decided to finish this box for the next preamp project
and maybe I will construct a new sub chassis
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
