Switchable Hi-Z input impedance, how ? - Page 41 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st November 2012, 09:12 AM   #401
juma is offline juma  Germany
juma's Avatar
Voltage doubler is OK (since power consumption of the gain stage is very small, couple of mA max) but gain stage has very small PSRR so it's recommended to use the clean PS.
Old 1st November 2012, 10:25 AM   #402
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I decided to focus less on scrap from now on
since this is beginning to look better I will buy two small print board trafos
one 2x 12V, and one 24V( or another 2x12V)
up to 5VA they don't cost much
Old 8th November 2012, 08:15 PM   #403
picking up the pieces
this have taken a slightly different turn, and I decided that the original box will be a stereo preamp, with two optional outputs
2 channels tube output, and another 2 channels balanced output with BA-3
might need this later for planned tube amp project
since its now a balanced BA-3 I need more space
cut a small piece off the previous tube 'board', and turned it 90 degr
Old 9th November 2012, 02:34 PM   #404
possible layout for the 2 channel SE-balanced output with BA-3
because its to some extend is exposed to radiated heat from the tubes Im trying make it even for all parts of the curcuit, and hopefully not have too much drift
Old 10th November 2012, 10:22 AM   #405
and the instrument high-Z input, low pass/high pass with EQ, a tour'de'france, the full route
Old 13th November 2012, 09:37 PM   #406
I might do another box
the height is better suited for any possible tube experiments
need a frontplate
and was lucky to get a Salas custom designed +30V reg
Old 14th November 2012, 09:04 AM   #407
nicely vented lid, but where is the rest
Old 14th November 2012, 01:46 PM   #408
shanx is offline shanx  Canada
Hi Tinitus,
Nice to see your continuing development. I have been checking your updates. Just thought I should send a quick post, I didn't have much to add to previous progress. Looks like you are pretty close to final for the Fet preamp.
Old 16th November 2012, 12:13 PM   #409
I have a small C-core trafo I hope will work
the regulated +/-12V from the 2x 24V, +30V from one 0-28V
Old 28th November 2012, 12:52 PM   #410
when ordering parts for my Salas reflektor I found theres a higher voltage LM317HV
will start out with that one, until I get the more complicated reflektor done
thats from the 28Vac down to +30Vdc
and I might also use 2x LM317HV as pre regs for 2x TO92 regs, to get the 2x 24Vac down to the +/12V I also need
the TO92 will be with the buffer
but man this is looking 'costly'
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
