Switchable Hi-Z input impedance, how ? - Page 39 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th October 2012, 09:38 PM   #381
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
you didn't say no, so I guess its the right one
box is getting on ok too
the back of an old TV is good for a piece of black plastic
Old 15th October 2012, 02:06 PM   #382
Originally Posted by juma View Post
Some characteristics are the same, some are not...
hmm, instead of On-Semi I should have looked at original Fairchild spec sheet, and I would have known
http://www.fairchildsemi.com/ds/J3/J310.pdf
whatever, I will probably choose a bigger 19" box
the small one will be ok too, but for a smaller project
it does have a nice back, but not much space for connectors etc
so I cut away most of the old tuner front plate
Old 19th October 2012, 09:36 AM   #383
moving on/off switch from the front to the back
Im using the hole where the removed mains voltage selector once was
looks like this preamp could turn into a 2-box affair
Old 19th October 2012, 11:14 AM   #384
added a cheap(scrap) mains out plug
Old 20th October 2012, 01:19 PM   #385
still cheap-skating
Old 20th October 2012, 08:25 PM   #386
wow, I had no idea a piece of 20year old and scratched poly plate could look this cool
just a bit of matte spray on the back, and voila, a fancy looking front
Old 22nd October 2012, 01:18 PM   #387
this paint spray is heavily toxic
only for 'sniffer addicts'
man I got real dizzy and sick
whatever, has to be done, somehow
small box turned out ok
needs more work tho
Old 22nd October 2012, 11:30 PM   #388
from old junk tuner to high end bass pre
and this is the one I will use
Old 27th October 2012, 08:41 AM   #389
mains voltage, on/off switch, fuses, aux mains out, trafo
Old 28th October 2012, 09:35 PM   #390
hey, juma, are you watching ?
would like to ask you if you have a suggestion for a good simple gain stage with the J310
could the j310/CCS buffer be changed to a gain stage ?
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
