Switchable Hi-Z input impedance, how ? - Page 37 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 12th October 2012, 08:27 AM   #361
juma is offline juma  Germany
juma's Avatar
Originally Posted by tinitus View Post
... like using two 2sk170 instead of the complementary pair...
What schematic (link, post nr.) ?
...would the trick work for combining j310 with BS170 ?
What trick ? Why/where combine J310 & BS170 ?
Sorry Tinitus, i can't see inside your head, please reference your ideas with links/post numbers...
Old 12th October 2012, 09:04 AM   #362
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
yeah, I get my silly ideas
well, like you said, maybe I better stick to the jboz, maybe with j310
my idea with j310 with BS170 ?
I might get burned forever for this
it would be like a bastard all N channel version of BA3 frontend
you have permission to shoot me now
Old 12th October 2012, 11:03 AM   #363
juma's Avatar
No need to shoot ... yet
BA3 is complementary, symmetrical, push-pull circuit. It' cannot be done with N ch. devices only. Same sex transistors allow for quasi-complementary, circlotron or single-ended arrangements, and neither of those can qualify for BA3
Old 12th October 2012, 11:06 AM   #364
OK, its already complicated enough
with the j310 being a tougher one, maybe a symmetric output buffer would be a better idea ?
but Im in doubt about all the resistors around the att pots
Old 12th October 2012, 11:13 AM   #365
juma's Avatar
1. What do you mean when you say: "with the j310 being a tougher one" ?
2. First you want all N ch. devices (and the buffer is a great place to do it) but now you want complementary pair, push-pull buffer ? It makes sense only if you want to drive the next stage which has 1k-3k of Zin...
Old 12th October 2012, 11:29 AM   #366
....... maybe a symmetric output buffer ....... ?
shoot, forgot I think you said j310 cannot replace a sk170, directly
any ideas ?
Old 12th October 2012, 11:35 AM   #367
......makes sense only if you want to drive the next stage which has 1k-3k of Zin...
dont know
I think you said 5v out, and isnt that more than sk170 ?
power amp load ?
could be 100k one day, and 10k the next day
I dont know
Old 12th October 2012, 11:56 AM   #368
juma's Avatar
Right, it will produce more undistorted voltage swing in the same topological form due to differrent construction (long gate vs short gate JFET), lower gm (lower gain being the price to be paid).
Old 12th October 2012, 12:01 PM   #369
juma's Avatar
any ideas ?
Not directly - they belong to different construction groups.
If you want complementary buffer with J310 first you have to find a P ch. complement for it.
And if you want a single ended buffer with J310 (like B1) you'll have to put up with Zout of few hundreds Ohms or to use coupling cap.
Old 12th October 2012, 12:46 PM   #370
sounds good to me, and what I had in mind, eventually
introducing the j310 kind of changed the picture, with its lower gain, and no buffers needed, apart from maybe the output
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
