Switchable Hi-Z input impedance, how ? - Page 36 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th October 2012, 12:30 PM   #351
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
found a perfect trafo, 20-0-20V, 0-6V
Old 11th October 2012, 12:45 PM   #352
juma is offline juma  Germany
Sin Bin
Tinitus, as I see it - you want a gain stage before the buffer, right ?
If so, please tell how much gain you need ?
What's the amplitude of the input signal ?
What is the preferred Zin ?
Old 11th October 2012, 12:57 PM   #353
hi juma
yes, gain stage-att-buffer
input signal ? Im not sure
but in any case it will end with having multiple gain stages
the jfet boz I use now is more than enough
but will also be attenuated at input
maybe 12db will do
and maybe even the output 'buffer' could have moderate 6db gain, and still have low impedance
I dont think it have to be a unity gain buffer
whatever will be convenient too
z-in ? about 1Mohm at first input stage
at other places through the amp, Im not sure
attached a couple of my messy ideas, just to show where I might be heading
and btw, its basicly the jfet related curcuits I want to look at right now
File Type: png bass pre layout 210 boz tube straight.png (39.6 KB, 45 views)
Old 11th October 2012, 02:16 PM   #354
Sin Bin
Yes, you should be OK with JBOZ - for less gain there is a J310 version...
Old 11th October 2012, 05:41 PM   #355
found it
yes, might be a good idea with lower gain
how is output impedance/drive for the j310 ?
if good I could just use that all the way, and forget about buffers... or ?
Old 11th October 2012, 06:57 PM   #356
Sin Bin
The Zout of J310 JBOZ is practically equal to Rd (680 R) which is OK to drive the Zin of the next stage of 47k or more. The usable voltage swing at the output of J310 JBOZ iz 5-6V peak (with more than that distortion becomes noticeable which might be acceptable in a guitar amp).
Old 11th October 2012, 07:38 PM   #357
passive baxandall load impedance seems to be something like 1Mohm, and falling to 80K above 1khz
should be ok then
need to get hold of some veroboard, and more components
thanks juma
Old 11th October 2012, 07:57 PM   #358
a few more bits and pieces that might work ok for a proto
Old 11th October 2012, 10:12 PM   #359
and to remind myself, remember to get some BS170 to try your sit trioda
Old 11th October 2012, 11:13 PM   #360
hey btw, just wondered....
like using two 2sk170 instead of the complementary pair
would the trick work for combining j310 with BS170 ?
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright 1999-2017 diyAudio
