Switchable Hi-Z input impedance, how ? - Page 33 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st September 2012, 09:42 PM   #321
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by tinitus View Post
and why the noise almost goes away with the stereo hifi preamp driving the output
must be something to do with going from 0/+ supply to symmetric +/- supply
looking at Nelson's B1 buffer, could this be the reason why he 'constructed' a pseudo midpoint for the jfet's grid to ground resistors
Old 22nd September 2012, 11:49 AM   #322
tried adjusting drain and source resistors
15ohm source res stays in, no doubt
not sure what kind it is
old and beige colored, so I suspect its a carbon film, 1/2W or something
tried a metal film, but didnt sound so nice
(signal resistors are metal films)
Drain resistor is lowered a bit, from 1K5 to about 1K2 or 1K3
measured +7.18V over drain res, and -82mv over the source res
dont know if those are the best values, but sounds good
Old 23rd September 2012, 11:20 AM   #323
nope, drain res is still 1K5
well, actually 1K6, since its 2 paralel 3K2
I removed series resistors from the power supply
and thats it
at input, instead of 1M to ground I have 850K
will try increasing input/gate series resistor
Old 24th September 2012, 12:49 PM   #324
shanx is offline shanx  Canada
Is it a hum? or more like white noise? I have a couple of suggestions, but depends on the type of problem. You may have a bit of ground loop on the input. Do you have an insulated input jack?
Old 28th September 2012, 06:59 AM   #325
ups, been busy
yes its snerring hum
my present setup have variable attenuation on final output, and takes away most of it(its a stereo preamp buffer)
at 12 o'clock nothing, but above that it begins be audible, and gets really aggressive when turned up fully
almost no hiss, and in general very silent right now
weird setup btw
bass guitar--compressor--jfet boz
then devides into two channels
one channel, jfet boz--headamp--stereo pre--poweramp--mid/tweeter
second channel, jfet boz--stereo pre--poweramp--woofer
inserting the headamp gives me a lot more control, and a picture of how it ought to work
I think it will work very well when Im able to control every gainstage in both channels
its getting closer
Old 28th September 2012, 07:07 AM   #326
btw
I have tried almost all possible configurations with the effect units I have, and some sounded pretty weird
one acted like a synth, another like pure distortion, and others sounded just muffled and phased
tells it not so simple at all with effect 'pedals
I only use compressor pedal unit right now
would like to do without, but right now its not possible
but maybe later
Old 28th September 2012, 12:44 PM   #327
For the hum situation, I would try an isolated input jack, input signal wire shielded from jack to jfet input, but shield terminated only at the signal ground directly at your jfet's source resistor ground. That is the most direct route for return path to your instrument. Adding a bypass cap across the source resistor may help. Check all other signal grounding points in your preamp are star grounded or bussed onto a heavy gauge copper grounding wire in your cabinet. You may need to add shielding metal panels in future if you are picking up ambient EMF. Your outputs are splitting to two different stereo preamps? You may have a ground loop issue there too. let me know if they are separate preamps powered on AC, DC etc. one output may need to be isolated to break ground loops on outputs.
Old 28th September 2012, 12:49 PM   #328
hey, will try bypass cap on source res
note, its not the channel splitting
hums also with only one channel
but its a proto built on a piece of plywood
the other evening I could hear faint spanish radio
but was gone again just by a simple off/on switching
seems to be a one time only
but I might have a faulty plug on my bass
its gets noisy when not touching the strings
Old 29th September 2012, 09:15 AM   #329
tried 22uf el cap
sounded ok, but a bit muffled, or maybe more like phased
then a 1.0uf film cap
sounded more open, but nervous
then 2.5uf
bang, sounds just right, very smooth
great 'egalite', responsive and tuneful, tight bass
I would say spot on
Old 29th September 2012, 09:50 PM   #330
2.2uf works ok too
actually, in some way even better
compressor sounds ok again
for some reason my compressor didnt work so well with 2.5uf
could be because it was a different type
also tried a 3.3uf orange colored cap
didnt last one minute
should I have a selector option, it would switch between 2.2uf and 2.5uf
worth the trouble ? yeah, its enough to make that little important difference
might be it actually affects the tuning pitch just a bit, but enough for 'certain occations'
anyway, a switch would at least make it easier to test different caps
well, enough of that
working on a simple regulated supply for the jfet
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
