Switchable Hi-Z input impedance, how ? - Page 32 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st September 2012, 10:23 AM   #311
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
a few small changes
LED/bleeder
resistor was mounted on the cathode/ground side
shifting the resistor to the anode/supply side lowered hum a bit
input-Z was set by a 1M5
changing it to 9K resulted in further improvement
connected as high-Z input on my head amp hum is almost acceptable now
dont know why, but the gain also seem to be more controlled now
and the sound is quite good
things to try, a regulated supply, and 2-channel output
Old 21st September 2012, 12:13 PM   #312
shanx is offline shanx  Canada
Hi Tinitus, The tube heater circuit could be giving you hum. What type of heater supply setup are you using?
Old 21st September 2012, 12:15 PM   #313
By the way, great that you got it up and running!
Old 21st September 2012, 12:32 PM   #314
hey, shanx
patience my friend, its so far only a small proto with a single 2sk170
Old 21st September 2012, 01:33 PM   #315
Ah OK!
Old 21st September 2012, 02:15 PM   #316
just fooling around, practicing, and testing
strangely, after inserting a hifi stereo preamp its now close to noise free
and just for the record, a describtion of this setup
bass guitar is plugged into a compressor effetc/'pedal' unit
and mostly because of its 12db gain and level control
signal then goes to the new jfet 'booster' proto
now with 2 channels out
and from there the signal goes to a hifi stereo preamp-buffer
originally built especially to drive the power amp I use
this setup sounds really great, and my best yet
now thinking about how to move on from here
I have a suspicion the jfet boz may not be the ideal high-Z input
but with some help it might become a great booster
Old 21st September 2012, 03:11 PM   #317
On my first stage jfet, I am putting a 10uF bypass cap,and a second 10uF across that with a switch. This to try different roll-off (should give a bottom end boost when switched in)
Old 21st September 2012, 03:32 PM   #318
lets know how it goes
did you consider to try with just a smaller film cap bypass, to 'boost' highs, and limit the lows, when/if needed
Old 21st September 2012, 05:40 PM   #319
I can give that a try, for sure
Old 21st September 2012, 07:58 PM   #320
no doubt, this little 'simple jfet boz' is good
need to think about how/where to use it
and why the noise almost goes away with the stereo hifi preamp driving the output
but I guess it also indicate theres nothing wrong with my jfet power supply
must be something other problem elsewhere
I have had problems with noise when not touching the strings
could be related to something on the instrument
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
