Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 7th August 2012, 09:18 PM   #261
tinitus is offline tinitus  Europe
for now, I think the input/muting switch will work like this
Old 7th August 2012, 11:21 PM   #262
only problem with above input scheme is, tuner isnt working while playing
my main problem seems to be that I insist on the middle POS-2 to be the muting mode
I cant see how, and its very annoying
and btw, the muting mode would actually be the tuner in muting mode
in reality its just a second 'direct out' plug
should be easy, but.....
Old 7th August 2012, 11:43 PM   #263
hey, while thinking about it, a few pictures
I managed to assemble the front
havent yet used the new smoked poly plate
so this is just some scatched clear poly, for the proto work
Old 8th August 2012, 08:04 AM   #264
ok, regarding input switch toggle postions, I decided to change it
normal playing have to be the middle position
while playing you have both tuner positions available
tuning while playing, and silent tuning
funny how easy it suddenly becomes
I call it audible tuning and silent tuning, because thats how I will use it
but preamp bypass would probably be more correct
Old 8th August 2012, 01:08 PM   #265
shanx is offline shanx  Canada
Thanks for posting pictures, seems to be progressing well.
Old 8th August 2012, 10:35 PM   #266
it feels better
less frustrated when I wake up in the morning
looking at the effects loop
right before the tone control curcuit might be a good place
maybe the loop swithc could also do tone bypass
but might be streching a bit too far but its tempting
Old 8th August 2012, 11:09 PM   #267
and possible front layout
getting crowded, but still doable, thanks to the LED's
if loop/bypass and tone bypass should be done with one and the same switch, then tone bypass will only work when effects loop is in bypass(off) mode
there is only 3 positions possible
but would be perfectly ok as there is no clean signal with effects anyway
hope that makes sense
now I only have to put it together, and make it work
Old 9th August 2012, 01:06 PM   #268
Hi Tinitus, don't worry too much on the switching as there are a lot of permutations. Just suggestion, but I would work on getting all the sections running with very basic switching for now, then you can see what works best and rewire the switches if needed.
Old 9th August 2012, 07:36 PM   #269
.........work on getting all the sections running with very basic switching for now, then you can see what works best and rewire the switches if needed.
absolutely
I know the effect loop will work
having tone bypass in the same switch probably wont
and I dont think I would throw in an exstra switch just for that
tone bypass is not that important
but a few filters could be....shoot, I forgot
ok, I have put in a couple more switches for the tone curcuit, to prepare for any filters no more space for any further crazy ideas
I think design process is finished now
Old 9th August 2012, 07:57 PM   #270
Time to make some music!!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2013 diyAudio
