Switchable Hi-Z input impedance, how ? - Page 23 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 25th July 2012, 09:05 PM   #221
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
rearranged the inside
tube board and solid state board shifted place
matches the new curcuit layout with BA3 at input instead of output
and thought I would like to see how it looks with tubes
Old 25th July 2012, 10:37 PM   #222
did a search on 3PDT
under pictures it revealed a ton of info how to connect a LED in bypass
yesterday I was unable to find anything
strange world
Old 26th July 2012, 12:37 PM   #223
shanx is offline shanx  Canada
Google Image Result for http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=11083 &g2_serialNumber=2
Old 26th July 2012, 12:45 PM   #224
Hi tinitus, you will want to do a ''true bypass'' where the section is switched out completely. I posted a link for the basic wiring. To avoid any ''thump'' sound when you switch over, a 1 meg ohm is sometimes added from signal line to ground on the input to that switched section. The Led occupies 1 section of the triple pole, usually switch to ground and complete the circuit. A cool option is to use a dual LED, like yellow/red and switch in either one depending on which ''channel'' or bypass selected.
Old 26th July 2012, 08:40 PM   #225
regarding the 1M ohm
I have seen some suggest to short the input of the bypassed curcuit
But I guessed the 'usual' 1M ohm to ground would do the trick
Old 26th July 2012, 08:57 PM   #226
yeah the 1 Meg will tie the input to ground even when switched over. As you are bypassing completeley that section, any small noise in that bypassed section will be also completely out of the active signal path.
Old 26th July 2012, 09:09 PM   #227
right now thinking about where to 'steal' the power for the LEDs
use one half of the +/- 18V from the jfets supply
or take it from the tube heater winding
in any case, it will ofcourse have its own regulator
or simply use a battery ?
sounds a bit 'weird'
Old 26th July 2012, 10:27 PM   #228
hmm, a very small trafo should not be any problem
Old 27th July 2012, 01:02 PM   #229
this one looks neat
Old 27th July 2012, 01:23 PM   #230
pretty cool little thing
measures 4.7Vdc, unloaded
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
