Switchable Hi-Z input impedance, how ? - Page 21 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 16th July 2012, 10:13 PM   #201
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by shanx View Post
Did you finalize your front panel controls? or still working out the details?
figured I would need more space for controls
changed the front today, and its crap
need to find some plain alu, and make a complete new control panel
Old 17th July 2012, 03:00 PM   #202
shanx is offline shanx  Canada
I would check around your area, see if any machine shops have some 2 mm alum plate lying around. They may be able to offer you at a good price.
Old 17th July 2012, 04:56 PM   #203
2mm will be ok
I might try with PVC in front of the 2mm alu
actually, that was was my original idea
this way I can write all 'functions' on my PC, and place them between the PVC and alu
Old 18th July 2012, 09:34 PM   #204
maybe this could be fun
Old 21st July 2012, 07:58 PM   #205
Passinwind's Avatar
Lookin' good.
Here's how I ended up doing mine, using the Broskie mono octal board with two 6SN7s, Welborne PS-8 power supply, and my own 6SL7 front end with active mids and bass (Baxandall) between the 6SL7 sections, with a passive treble circuit following the second 6SL7 section.
Sound clips:
Electric upright, direct to sound card.
Fretless bass guitar, also straight to sound card.
Old 21st July 2012, 08:09 PM   #206
Originally Posted by Passinwind View Post
Here's how I ended up doing mine.....
very nice
Im looking for control knobs
where did you find yours ?
only, with two channels I need twice as many
scares me a bit
big risk it will be messy
oh, btw, waiting for a new front plate, smoked poly
a friend said he would get it for me
Old 21st July 2012, 08:26 PM   #207
Passinwind's Avatar
very nice
I'm looking for control knobs
Thanks, I am pretty happy with how it came out. Those are Jensen transformers on the input and output. I will probably post the whole Spice simulation eventually as I am looking to refine my modeling capabilities and could use some experienced input. I mainly used Spice to get the tone controls in the ballpark of what I was looking for, and it worked very well for that.
Those are Alco/Tyco knobs, sold by many vendors worldwide. I got mine from Marvac for under $2 each, but Small Bear sells them for a bit more as well. Since you're in Europe I assume you will likely do better with someone more local though.
Old 22nd July 2012, 07:22 AM   #208
front layout could be something like this
not sure I want to bother with effects
I prefer a clean sound with only small variations
Old 22nd July 2012, 07:58 AM   #209
funny thing that the sound needs to be 'correct', and match the music, or I cant play properly
Old 23rd July 2012, 10:06 AM   #210
closing in on the final front layout
looking complicated with output selector and multiple bypass switches
and all the diodes indicating signal or bypass (light off)
and I have no idea how
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright 1999-2017 diyAudio
