Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st June 2012, 09:25 PM   #171
tinitus is online now tinitus  Europe
man, I forgot it would need two controls per tone control curcuit
its beginning to look a bit tight
and forgot I also need a mute switch
if bypass switch has 3 positions, mute could be in the middle
but a toggle switch might be easier and faster to use
opinions ?
Old 21st June 2012, 09:36 PM   #172
bypass switch
I think it will take the signal directly to the solid state output, through a hi-z input jfet buffer
this way it will also be functional without tubes
and I will need a way to bypass any effect devices connected to input side
man, I hate it, but might have to put the power switch on the backplate, to get more room on the front
Old 22nd June 2012, 02:55 PM   #173
ahh, regarding switches and bypass functions, there seems to be a few basic terms one needs know
single pole single throw = SPST
single pole double throw = SPDT
and so on
or if much more variations, there could be numbers instead
might be handy when looking at switches specsheets
and to know exactly which model to buy/order
for the bypass function we may need look only at SPDT, DPDT, 3PDT
Old 22nd June 2012, 04:45 PM   #174
cleaned out schematic a bit, and getting closer I hope
Old 28th June 2012, 03:32 AM   #175
shanx is offline shanx  Canada
A mute position on the middle of bypass (channel?) selector switch would seem to be the proper place for it
Old 28th June 2012, 12:02 PM   #176
Originally Posted by shanx View Post
.... selector switch would seem to be the proper place for it
most likely, yes
Im working on it
with regards to attenuation pots, the tone controls seem to be a bit of a problem
but I could ofcourse just fill it up with buffers
thinking about using only one tube instead of two
but easy to change
Old 28th June 2012, 01:20 PM   #177
Hi Tinitus,
If you are having problems with tone stack, maybe you should download Tonestack Calculator from Duncan Amps. It is free and very useful for setting up different resistance and capacitance. There are a lot of styles too, fender type vox, marshall. You could ''tune'' the response curves for bass. Are you getting too much signal attenuation on your tone controls?
Old 28th June 2012, 04:25 PM   #178
looks like I mostly need cut/attenuation
but might be too early to say yet
having seperat biamped midrange and bass channel may change things
should give me more control
at least that was one reason of doing it
if Im very lucky I wont need anything else
Old 30th June 2012, 08:25 AM   #179
hey, for a first try, with tube curcuit only, I could try the trick with a 'too small' bypass cap on the cathod resistor
maybe something like 1uf
or selectable cap size/options, by a simple switch
Old 30th June 2012, 08:58 PM   #180
while waiting for power supply parts, hunting 6n1p curcuits
but why are there not two curcuits using same resistor values, or at least just the same anode voltage
but no, all different
could it come from 'adoption' of ecc88/6DJ8 curcuits
but 6n1p is not exactly the same
and 'ev' types maybe even more different
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
