Guitar Tube Amp that uses KT88, 300B, 2A3, else - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 23rd August 2003, 07:37 PM   #1
zxx123 is offline zxx123  United States
Default Guitar Tube Amp that uses KT88, 300B, 2A3, else
I have never heard about it. (@Some bass amp uses KT88)
6V6, 6L6, EL84, EL34 and what else? In addition, they are
all PP type. (@some lunch box type tube amp used SE.)
Can you explain why? I think SE typed 300B will
sound better and more beautiful lead tone.
If you are using such amp, can you share your experience?
Old 23rd August 2003, 10:58 PM   #2
Brett's Avatar
I can think of a few reasons why DHT's aren't used in geetar amps; expensive (and tube amp maunifacturers are incredile cheapskates), fragile, low power, unknown in MI circles, more complicated to use, tradition and inertia. Lots of bass amps use the 6550, but I don't think the tone is correct for a lot of guitar applications.
I'm just finishing up a 300B SE geetar amp for a friend. It has a luvverly tone, like butter.
Old 23rd August 2003, 10:59 PM   #3
djmiddelkoop's Avatar
Guitar amps are designed and used for there specific distortion, depending indeed on the output tubes used.
The players are mostly not interested in the clean sound of 300B or other SE output tubes, but in the way they distort when overdriven.
This plus the output power needed is why PP outputs are used.
Hope this answers your question.
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 24th August 2003, 12:21 AM   #4
diyAudio Senior Member
fdegrove's Avatar
While I understand the underlaying message, I don't really consider the 300B clean or neutral.
One could construct a bass amp with a 300B that, given the right speaker would appeal to this kind of user.
A good 300B doesn't cost an arm and legg.
I know guitar players who pay a similar amount for a set of 6550s...pretty soon there may be some guitar amps out there using SE 845s or 211s.
Who knows?
Anyway you look at it, this is all about tone, bite, whatever harmonic balance one's after.
Viewed that way any amp is bound to bring a particular palette of tonal colours.
Frank
Old 24th August 2003, 12:26 AM   #5
316a is offline 316a  England
316a's Avatar
Default Filaments
Who knows?
...one point to note : would the filaments of the DHTs survive gigging and constant transportation ?
316a
Old 24th August 2003, 12:31 AM   #6
fdegrove's Avatar
Good point...
I doubt they would....what was I thinking?
Heck, even those trusty 5881 and 6L6s hardly survive the roughs..
Maybe that's where the U2 " Rattle and hum" title came from??
Frank
Old 24th August 2003, 02:56 AM   #7
Brett's Avatar
Default Re: Filaments
316a
Nope. The one I've built, and it's soon to be made twin, are only for studio use for that reason.
Old 24th August 2003, 06:43 AM   #8
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Why use an obscure 300B telephone tube for 6-7 Watts, when you can get nearly as much power out of a cheap 6V6 run hard?
At least thats what I would have said IF I worked for Fender in the 1950s...
Old 4th December 2004, 01:05 PM   #9
pingfloid's Avatar
Lightbulb 300B Guitar amplifier
I believe that a 300B guitar amp will have what I need: warm tone at very low volume, to play at home and mike the amp to record. I have a spare 300B and a old small valve amplifier crying to be reborn, so I will completely rebuild it with a new 300B design.
About the schematic, all i've seen so far is for hi-fi. Maybe I will start with the WALTON and then use a real guitar pre-amp schematic with tone control. Any sugestion?
Manuel:
Old 4th December 2004, 01:17 PM   #10
Default hmm not bad idea i think
since the day i wrote this post, i have built a lot of single ended guitar amps such as fender champ. my conclusion is that 6v6 is not enough to make modern distortion, but good for blues and jazz. 6l6 or el34 is not bad. they sound great distortion in low volume, but not much bass and damping)
definitely, all of them are for practicing at home. i think 300b is not bad. i expect a lot of harmonic distortion will give thicker tone.
however, well, i can build up two more champ with the mony cost for 300b single ended guitar amp.
SE 300B or PP KT88 amps? arvin Tubes / Valves 73 15th June 2013 07:49 AM
WTB: Single KT88-EH tube quadtech Swap Meet 0 17th March 2009 02:31 PM
Quicksilver 300b monoblock (KT88 conversion) eleakist Tubes / Valves 4 18th June 2007 12:50 PM
spl for 300b, kt88 tenderland Tubes / Valves 4 23rd November 2004 01:44 PM
New production Tesla KT88 and 300B not JJ kgbamps Swap Meet 0 25th January 2004 05:12 AM
Copyright ©1999-2017 diyAudio
