| Instruments and Amps Everything that makes music, Especially including instrument amps. |
hi there,
i need some help, i built a EL34 amp with ECC83 pro-amp for my quitar. at the 1st level (the ecc83) i`m try to built an equalizer (bass&treble) and there is hum. the input is the A point if i move the input on the 2nd gril (pin 7)of the tube, the amp play`s perfect,without hum. i bielive that i got some kind of feedback betwin 2 levels of ecc83. how can i remove it.... any suggestions? |
#2 |
I presume that you mean that the input is at the grid of the first valve (not the plate) when you are getting hum.
There is something strange about that circuit. Is it really a 5.6k plate load resistor on the first triode. Seems way too low for a 12AX7. And where does that capacitor on the grid of the first valve go? Some kind of global feedback?
mike - www.keepingsundayspecial.org |
#3 |
There should be no global feedback in circuits which contain bass-treble controls.
The hum problem might be due to ground loops or a poor layout in the tone control circuit. If the wire runs are long, shielded cable is absolutely necessary because the tone control circuit impedances are high. A full schematic of the preamp would help.
Frank |
#4 |
there ...all the schematic view...
about the ground ... at the equalizer nothing grounded....how i got hum from this... |
#5 |
shielded cables are already used.
something i didnt said ,i `m not use pcb for the equalizer. just wiring the compoment on ponts. and are as short as i can. |
#6 |
looking at this schematic it is not correct for a guitar amp.
input impedence must be stabilized first. the volume knob should be after the first tube stage. this looks like a hi-fi amp the way the input is set up. a very good example is : http://www.drtube.com/schematics/vox/ac501976.gif and http://www.drtube.com/schematics/gibson/ga-1rt.gif and http://www.drtube.com/schematics/marshall/jtm45tr.gif Last edited by DavesNotHere; 27th June 2011 at 04:03 PM. |
#8 |
If you bypass the first stage cathode resistor it will help reduce hum.
But for a guitar amp you would be better to choose a different circuit that is designed for guitar rather than hi-fi. |
#9 |
i want an explanation.
at the ecc83 (v3) we got an 4.7 k ohm potentiometer and a capacitor . for what reason is there.?? adjust the voltage of the cathode? and how many volts must be? Wireshark Cookie Dump:
OKCancel |
#10 |
hi again,
at this guitar amp we got an ecc83 ( place v3) , 2 resistors serial connected and a potentiometer .what for is that (the potentiometer). any explanation the reason of the existence? adjust anything? Wireshark Cookie Dump:
OKCancel |
| Hum in Crate guitar amp | Monsteranus | Solid State | 15 | 21st March 2011 05:45 AM |
| Cmoy Pre-Amp ground hum | sled108 | Chip Amps | 6 | 3rd June 2008 11:57 AM |
| Frustration with hum and noise in guitar tube amp | voivodata | Tubes / Valves | 18 | 24th May 2006 10:15 AM |
| Guitar Amp Hum Question | Trout | Tubes / Valves | 5 | 21st October 2005 07:54 PM |
| Page generated in 0.10467 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
