Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th August 2011, 04:03 PM   #981
scott17 is offline scott17  United States
scott17's Avatar
Here are the guts of the little 6AF11 amp.
Old 28th August 2011, 05:05 AM   #982
Default 6AF11 amp
Neat, compact, cool
Cheers, JimG
Old 28th August 2011, 02:31 PM   #983
kevinkr's Avatar
Very compact!
Nice job...
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 28th August 2011, 04:04 PM   #984
Personally I hate doing ship-in-a-bottle builds. But whenever I have lots of space I get ideas of adding features and the space just disappears. That being said, I see room enough in their for a reverb loop (hint, hint). Just kidding.
Old 28th August 2011, 05:07 PM   #985
tubelab.com's Avatar
I used a compactron in an amp once and found it would be on the verge of squealing at full gain.....It took a quite a few iterations to eliminate the squealing oscillation but I finally got it out of there.
I have waffled back and forth on the compactron amp idea. I started one on perf board with sky wired parts and clip leads. It was a good multi frequency radio and TV jammer so thats where it stopped. I may revisit it if there is time but it doesn't look good. There are 3 pin comaptible tubes that fit. The 6AF11, the 6AS11, and the 6BD11. They are all in good supply and two are on the dollar menu.
My design uses two tubes. The high Mu triodes are the preamp stages the medium Mu triodes are the PI and the pentodes are P-P output. I get about 10 watts out of it cranked. No distortion numbers or clean power readings were taken since I never tamed it. I started a PC board layout but came to realize that trying to use two tubes with the signal going back and forth between them isn't a good idea. The layout could not be optimized.
Made PC boards for two new experiments last night. One is a 4 tube version of Amp 1.0 and the other is just a preamp with 2 tubes and a "distortion maximizer" circuit. Haven't had time to cut and drill them yet.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 28th August 2011, 07:26 PM   #986
Used the 6T10, dual pentode. The signal pentode is dual control, played with the voltage on it but it did not change things too much. Did it point to point, might have better luck putting it on a board. Ultimately it was the lack of power that made me put it aside.
Old 28th August 2011, 07:48 PM   #987
scott17's Avatar
I really like it for the compact size but it was difficult to wire. I had the circuit jumper-clipped together on the bench and had it working, but low and behold when I mounted everything in the chassis, there was that pesky oscillation again. Stupid wiring mistake on my part.
Reverb loop? In there? HA! Luckily I have have an external digital reverb.
Old 29th August 2011, 04:13 PM   #988
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
Then you gotta love this one. I have a soft spot for small and cute things but....damn, I'm beginning to think I bought too small a chassis. LOL. That OPT (believe it or not) was the partner of an ECL86 output tube (vintage reel to reel tape recorder).
Old 29th August 2011, 04:46 PM   #989
Trout is offline Trout  United States
Trout's Avatar
That's what she said j/k
Is that a pedal box? I think I have a couple about that size setting here. I always planned on doing one of those 6021 sub-micro amps but never got around to it.
Old 29th August 2011, 05:13 PM   #990
Cassiel's Avatar
Yeah, that's for a pedal box.
Yeah, that's what she said. So I built this as a gift for our first year anniversary.
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 12:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 02:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
Copyright ©1999-2013 diyAudio
