The Hundred-Buck Amp Challenge - Page 63 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th July 2011, 12:19 AM   #621
Tubelab_com's Avatar
Welllllllll, after a whole rainy day of tinkering I now know a whole bunch more things that don't work. I got my output stage and PI up and running. It makes 15 watts with a real OPT.
Some of the budget transformers I tried couldn't make more than a watt or two without distorting badly. The Cheap P-P OPT from AES can do 12 watts which isn't bad since the real one that I used weighs 5 pounds. I found a tiny little power transformer that will make 8 watts, but the DC resistance is so high it starts smoking after an hour even at idle.
I had planned on using the N-68X for a power transformer but even though the Kill a Watt reads 44 VA the transformer is too hot to touch. If I switch to a choke input supply I go over budget and lose half of my power.
Time to rethink a few things.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 18th July 2011, 02:57 AM   #622
I thought, I tested. Repeat.....The more I tinkered the worse things got. Before long my mighty amp was making 3 watts, I could get that out of the PI if I stuffed the right tube in there.......not a bad idea........
I decided to put it all back the way it was before I started messing with it. Crank the bias back up to what it takes to feed some hungry tubes. Power at clip is 14 watts and the Kill A Watt reads 65VA. Time to get a bigger transformer and rethink what I'll need to leave out to make budget.
So far this circuit is far too HiFi. I couldn't make a HiFi amp this cheap and this clean if I tried. At 5 watts the distortion is 0.85%, at 10 watts it is 1.8%.
OH, that was the little version.......The board with the plate capped sweep tubes hasn't been powered up yet. Don't think that one fits in the budget...yet, but I had time to kill while I was up north, so I laid it out anyway.
Old 18th July 2011, 03:44 AM   #623
TheGimp is offline TheGimp  United States
TheGimp's Avatar
The $100 guitar amp thread interrupted my thoughts with respect to the 6P41S as a potential SE amp.
Tonight I finally got around to wiring up a servo to control the bias supply and flogged it to 8W out thorough an Edcor 3.5K opt with a B+= of 300V.
Glowing like a metal on the edge of a knife...
350 V b+ and the whole side begins to glow with an output of 9W.
The 2.5K opt does not do any better even thought the load line looked better.
Old 18th July 2011, 05:49 AM   #624
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Yes, one more potential guitar tube: 6P41S. But 8W is way overkill.
The Devil is not so terrible as his math model is!
Old 18th July 2011, 09:11 AM   #625
wdcw is offline wdcw  Australia
Originally Posted by Printer2 View Post
Not bad. Check out how it sounds at the edge of breakup.
Gday Printer2,
Yeah it has a very smooth transition at breakup, it's not to bad for the first attempt from paper to actual circuit.
I am just running some more numbers to try to get it closer to what I want.
For myself I find it more useful to do the prototype work in a chassis, for safety & so there is little change in sound between say breadboarding or open circuit work on a bench to the actual finished thing in a chassis.
It never ceases to amaze me how things can change soundwise from a prototype on a bench to the actual finished thing in a chassis.
I have some new idea's I will try out with this circuit, just hope they work out ok.
How about some of you other builders put up some sound clips, as you can see the response is overwhelming haha!
Can't wait to hear some.
Cheers
Old 18th July 2011, 09:25 AM   #626
hunoz is offline hunoz  Australia
Hi wdwc,
What did you use for the chassis? Looks galvanised steel. Is it from a hardware store? I am looking for cheap solution for prototyping for my ideas/projects.
Many thanks
Old 18th July 2011, 10:17 AM   #627
Originally Posted by hunoz View Post
Hi wdwc,
Many thanks
My apologies wdcw. It seems my fingers messed up again. I can't seem to edit my message to fix my typo. Hence this post to correct my mistake.
Old 18th July 2011, 11:01 AM   #628
Hi wdwc,
Many thanks
Gday hunoz,
Yes this is a cheap solution to the problem of chassis, this is 150mm wide Galvinised Steel Purlin--used for sheds, roofs etc.
This piece is 150 X 350mm long & cost $4.00 or you can buy a 6Mtr length for $69.00 & cut it up which is what I do.
You Can get 100mm wide or 200mm etc & it's perfect for chassis.
No need to worry about typo's, I make plenty of mistakes.
Just remember-- VOTE for wdcw hahaha!
Hope this helps out.
Cheers
Old 18th July 2011, 11:19 AM   #629
Originally Posted by wdcw View Post
Gday hunoz,
Cheers
Thanks mate.
I just found it on the net too as your reply arrived. They got it in Williamstown which is a bit too far from here, but I hope they have it at Bunnings or some other building supply place closer to me. It sure looks good to me for chassis.
I too prefer to test my ideas as the finished product will be as I also found that parts placement can be critical to the final sound.
Voting for you? SURE thing! that is, if I like your project the most
Old 18th July 2011, 11:41 AM   #630
Thanks mate.
No problem glad to help out, steel merchants also sell it, shop around as prices vary a lot, you know what it's like.
Cheers
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 12:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 02:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
Copyright 1999-2017 diyAudio
