| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#551 | |
#552 |
I was thinking about it, but I don't have a dual pot with different values of gangs. What I come with, you see on schematic: connecting the gain pot to the same point where feedback capacitor goes I made depth of boost of highs dependent on volume control. I will put the result on youtube.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#553 |
Let me say it again rather than responding individually: I was not talking about any amps or projects built would be unsafe or that such a thing would be advocated here. My concern was relating to working on projects that are on untidy benches with loose wiring and tools cluttering the work area and the safety implications of such practice.
I was taught to work on clean and tidy bench with safety isolation transformer on top of the bench and using it. When I was taught, we had to work with one hand in our pocket. After many years of working on amps, my practice of fully tidying up my bench and/or putting one hand in my pocket lapses and sooner or later I will end up having a minor accident. I have blown test equipment, got shocked by accidentally shorting something I did not intend to and also by forgetting to discharge ALL the caps. Given time not having any mishaps, we all get more comfortable then we should be. After all we are all human and we think this kind of thing will not happen to me. The older I get the more and more I make sure I do not start work at my bench if I am rushed to go out in an hour and there is a chance I may need the whole hour to finish what I started. Equally it is not a good idea to start working if I had a blow with my wife. Frustration is not a good friend at the bench! At least not a good friend for me. I am not advocating that any of you should follow the above, but if you had any mishaps in the past, recognise any of the situations I referred here then you may want to think about my concerns. |
#554 | |
#555 | |
![]() I don't remember what was burning, but I remember myself sitting on the chair in the front row, trying to calm down...
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. Last edited by Wavebourn; 12th July 2011 at 12:35 AM. |
#556 |
Now it does not sound so terribly when overdriven, but is not it too thin when played clean? Additional sneaky control with feedback seems to fix it: low end cut depends on gain control knob's position. Both pots, tone and gain, are inter-dependable. Should I patent it, huh?
![]() YouTube - World Champion guitar amp project -- overdrive tone control added
#557 | |
Mind you this is during my hobby time. At work you are paid to get the job done, tired or mot. Working in industry some of us do not have the luxury of a workbench or even good lighting. More often than not I crawl into places with my trusty Magllite, a while back had a trouble light behind me with a 600V 3 phase speed drive half apart on the wall while standing on a ladder (No hand in my pocket as I needed it for three point contact), wondering why I left that cushy repair job. In a perfect world we would have all the tools and time at our disposal at work and at our hobby to do things right. Sadly this is not a perfect world. |
#558 | |
#559 | |
![]() Here are pictures of my current breadboard: preamp and power stage, using sub-miniature tubes. 6N21B tube can be replaced by 6N2P or 12AX7, 6P30B can be replaced by 6P1P or 6V6.
#560 |
Your project is interesting and the sounds of your amp is not bad either. Keep improving it as I am looking forward to see the final version. I would especially like to hear it with a 6V6.
| Hafler Five Hundred problem | hatrack71 | Solid State | 4 | 10th June 2009 12:38 PM |
| most bang-for-the-buck sub-amp | skogs | Solid State | 12 | 8th September 2007 10:22 AM |
| Buck & boost transformer | Ilianh | Parts | 1 | 15th March 2004 06:03 AM |
| a hundred questions from a noob | zoobie | Solid State | 5 | 31st May 2003 02:04 PM |
| Nineteen Hundred Ninety Nine Posts And Counting ;-)... | mrfeedback | Everything Else | 12 | 21st May 2003 05:59 PM |
