| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#41 |
One thing certain, Just Radio's out of Canada has great pricing on Electrolytic's for the PS as well as film caps.
Bonus, he is VERY reasonable on shipping and does world wide sales as well Price List and Order Form for CAPACITORS for Antique Tube Radios Antique Radio Schematics and Capacitors for Tube Radios |
#42 |
I did a little digging around on my old PC and found some clips from the 6AQ5SE amp I built in 2005.
I have always been a fan of those babies. This one had used a single 12AX7, a 6AQ5 & 6CA4/EZ81 rectifier. It had a cheap OT from Triode Electronics. TF103-48ul FENDER CHAMP STYLE 5W OUTPUT TRANSFORMER TF103-48 Single Ended Ultra-Linear 4 / 8 Ohm MADE IN USA Close Mic recorded with Shure SM57, a hint of reverb added post with cakewalk software. 12" speaker & Fender Strat Basically a modded AA764 Champ circuit. A Little Noodling Cranked for Feedback I always found that particular OT a bit weak especially on the bottom end but it was cheap & worked. Last edited by Trout; 14th June 2011 at 02:28 AM. |
#44 |
^post#1 just the head.....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#46 |
#47 |
#48 |
I got the idea of using the 12W6 from wavebourn, they sound fantastic in guitar amps and at U$1 each who can complain?
i have a suspicion they will sound even better in hifi amps....
#49 |
Not trying to pee on the party tray or anything, but here's my 2-bits:
What a weird contest. The elusive goal with practice amps is always in creating one that sounds decent while still being cheap and quieter than a "normal" guitar amp. But, nobody has mentioned sound as a criteria here. If participants are the judges, as described in post #1, then I fully expect the winner to be an exceptionally creative and impressive circuit, that has a 50% chance of sounding like a cat retching when you play a song on a guitar that's plugged into it. If the judges were, instead, DIY guitar amp builders (i.e. real guitar players) who judge the amps based on their sound, then you've got a real guitar amp contest, IMHO. But then you can't expect them to build and audition them all and cast their ballot in just a month or 2. And if it's not about guitar sound, then what's it about? Circuit design? Then why a guitar practice amp? What a weird contest. Also, why 2-5 watts? There are plenty of good practice amp designs out there that push far less than 1 watt (12UA7 or 6CG7 as output). If you happen to want Eddie Van Halen's sound, even 2 watts will practically blow your windows out. I'd suggest "5 watts or less" rather than 2-5 watts. ..todd Last edited by taj; 14th June 2011 at 04:13 AM. |
#50 |
I did, actually. It will be an amp for practice and studio recording. And I have something more in mind...
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
| Hafler Five Hundred problem | hatrack71 | Solid State | 4 | 10th June 2009 12:38 PM |
| most bang-for-the-buck sub-amp | skogs | Solid State | 12 | 8th September 2007 10:22 AM |
| Buck & boost transformer | Ilianh | Parts | 1 | 15th March 2004 06:03 AM |
| a hundred questions from a noob | zoobie | Solid State | 5 | 31st May 2003 02:04 PM |
| Nineteen Hundred Ninety Nine Posts And Counting ;-)... | mrfeedback | Everything Else | 12 | 21st May 2003 05:59 PM |
