| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#1451 |
#1452 |
I`m glad you enjoyed the vid! :P This is the amp only, no effect og distortion. It does sound better in real life. The camera I used was a Canon G7. The audio on the camera is crap, but as you can hear, the fuzz is there!
The speaker is a 3W RMS 6` Fullrange I bought of eBay. It looks like a vintage radio speaker I think. In my ears, the sound is perfect. If I were to choose a different speaker, what would you guys suggest? I have built several amps earlier and are familiar with schematics and basic tube theory. But I`m blown away over the amount of work this guy has put into the step by step instruction. EVERY single solder joint is well described, and it comes with a ton of pictures and tips and tricks. I cannot stress that enough, it simply amazes me. Thanks! |
#1453 | |
#1454 |
Banned
Try it out, it will work good. That little amp can power 4 x 12" speakers as long as they are reasonably efficient.
I did not realize you had a 6" speaker in there, it looked smaller. |
#1455 |
WGS speakers are affordable and pretty good quality.
#1456 | ||
But on the other hand, If you HAVE another speaker, by all means connect it up and try it. You might find a better "perfect". A 12 incher might fatten up the sound a bit. Quote:
I think that squeezing Voodo Chile through a $90 amp and getting this much sound is impressive indeed. Love the country twang too. I saw a black Strat in some of his other videos. I can understand how you get Voodo Chile from a Strat, but how do you get the twang?
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#1457 | |
The output transfomer is actually a 6.3V filament transfomer. 110/6.3V. I never knew they could be used as a output tranny. I fancy that! Yes I use the black strat here with standard USA pickups. Perhaps the twang comes from all the Cash/Luther Perkins I`ve been playing for so long :P |
#1458 |
Hi Guys! I have been enjoying this thread for a while. I plan on building several of these amps. The first one I tried is Tubelab's 1.3. Im not nearly as knowledgeable as you are, so Im learning as I go. Im having some issues. The output transformer I assume is wired across the 70 volt taps, using the orange lead as the center tap, with the black and purple going to the power tubes. The amp works, but only with the volume cranked, and the tone all the way down. Otherwise it makes a terrible noise. I don't think its oscillation, but Im not sure. It hums quite a bit, too. I tried to go point to point, but it ended rather messy. Should I start over on a perf board? Opinions?
#1459 | |
So the notch was actually put there to make the overall frequency response of amp + guitar flatter, and take away the midrange peak from the pickup. Other amps of the time had a tendency to sound more nasal or midrangey, because they didn't take out the peak in the guitars frequency response. You can still hear that more nasal tone in amps that don't use a Fender tone stack, for instance in some of the 18 W Marshall clones that use a one-knob tone control. (The one-knob tone control does not have a notch in the frequency response.) Later Marshall amps modified Fender's tone stack for more gain, but kept the notch in the frequency response, though they shifted its frequency a little to get a somewhat different sound. Guitar pickups have evolved over the years, so one unanswered question is whether the notch in the Fender tone stack response is in the right place to correct todays Fender guitar pickups or not. Of course all Fender pickups are not the same today, and there are also hundreds of other brands and models on the market. The notch in the amp cannot possibly be in the right place to compensate for all of these different pickups available today. You can read more about the design and intention of the classic Fender tone-stack here (scroll down to the section on tone controls): GM Arts - Guitar Amplifiers I've wondered whether a combination of a tunable notch (frequency and Q) and a Baxandall type control, one feeding the other, might make a good guitar amp tone control with the strengths of both Fender's stack and the Baxandall circuit, and more versatility than either one by itself. -Flieslikeabeagle |
#1460 |
Single knob tone stack in Post 1396 has mid-scoop. I designed it using the Duncan tone stack program.
Cheers, JimG PS. Ignore connection from OPT to ground - doh! |
| Hafler Five Hundred problem | hatrack71 | Solid State | 4 | 10th June 2009 12:38 PM |
| most bang-for-the-buck sub-amp | skogs | Solid State | 12 | 8th September 2007 10:22 AM |
| Buck & boost transformer | Ilianh | Parts | 1 | 15th March 2004 06:03 AM |
| a hundred questions from a noob | zoobie | Solid State | 5 | 31st May 2003 02:04 PM |
| Nineteen Hundred Ninety Nine Posts And Counting ;-)... | mrfeedback | Everything Else | 12 | 21st May 2003 05:59 PM |
