3 channel all tube preamp pedal w/fx loops for all clone build - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd June 2011, 11:22 PM   #1
jamhard is offline jamhard  United States
Red face 3 channel all tube preamp pedal w/fx loops for all clone build
Ok, I have schems 4 mesa triple rec. Want to build a pedal(#1clean#2,3red dist) with outs for all channels for routing separate fx, then line mix, then power. Power and line mix easy. Preamp build a little complicated. Each channel will have gain, presence, master, 3 band eq. After eq, the outs. The power transformer and choke I don't know what to use. I'm trying to keep to the original schems, since I am not a designer or experienced amp builder. Although I do have a.good understanding of electronics. And consider myself to be smarter than the average bear. And I don't know how to prep the signal after the eq to be able to send through fx pedals. Help?!? The schems are all over the net if you're curious.
line level fx - integrating them into standard fx pedal chain jmp220478 Instruments and Amps 1 13th February 2011 06:29 AM
I Want To Build A 100+Watt per/channel Tube Poweramp ak_47_boy Tubes / Valves 29 17th October 2007 11:16 PM
Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) powertriode Tubes / Valves 57 11th August 2007 07:59 PM
Big Muff FX pedal cqboling Instruments and Amps 10 27th November 2006 01:05 AM
looking for a new spin on guitar fx pedal psu rockstudio Instruments and Amps 2 7th April 2006 03:29 PM
Copyright 1999-2017 diyAudio
