Anybody else here build or modify tube guitar amps? - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 4th June 2012, 06:02 PM   #21
doozerdave's Avatar
Originally Posted by gingertube View Post
Latest project (order from a friend) is a Push Pull 6V6 guitar amp using all 6SL7 octals for the preamp and phase splitter (concertina).
I just finished a quad 6V6 PPP amp (using 9 pin dual-triode preamp tubes) using a concertina phase splitter and the feel and sound is fantastic. I briefly tried an LTP PS and it made the ouput harsh and the feel was way too snappy. I'm using a big OPT out of my Fender Super Reverb so there is a tonne of headroom and the LTP PS was too much.
-Dave
Old 4th June 2012, 11:35 PM   #22
Dave,
It has been my view for a while that the concertina splitter is one of those "best kept secrets" of great guitar amp design although I note that it is making a come back. A lot of people arre starting to use them again. I found best results when using a high mu triode (12AX7, 12AT7, 6SL7) which tends to emphasize the sonic "warts" of the concertina and it is those "warts" which sound good in a guitar amp. This is in contrast to the concertina used in a HiFi Amp where a low mu triode is best (12AU7, 6DJ8).
Did you use the Merlin Blencowe recommended big grid stop on the concertina triode?
Ian
Old 5th June 2012, 02:16 PM   #23
chris661's Avatar
Update - using a rediculously over-done linear power supply (126v @ many amps) to alter the cathode voltage of the 2nd valve, I've managed to get the amplifier running A2. More power!!
Chris
Old 5th June 2012, 09:48 PM   #24
doozerdave's Avatar
Dave,
Ian
I didn't use a fixed grid stopper as I have my master volume control right before the concertina. I'm currently using a 12AX7 in there, and have tried several other tubes, but have also found that the AX sounds the best. I will definitely be using concertina PI's in the future.
-Dave
How can I modify this grommes little jewel amp for guitar. JZatopa Instruments and Amps 10 2nd April 2010 10:39 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
How to modify Our Bass Guitar Pickup? thomgun_lc Instruments and Amps 28 22nd June 2008 06:25 PM
modify eagle el84 for guitar psychosteve Instruments and Amps 7 17th November 2004 10:58 PM
Op Amps in Solid State Guitar Amps MrGuitardeath Instruments and Amps 1 11th February 2004 07:43 PM
Copyright 1999-2017 diyAudio
