Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 10th April 2011, 05:47 AM   #1
Lightbulb high-power effects adaptations
Just out of curiosity, has anyone ever built or considered building high-power versions of circuits such as the venerable fuzz face or big muff? The thought crossed my mind the other day and its been bubbling around my head since then. By high-power I don't mean using a higher power supply, but actually changing all the parts to handle higher currents and voltage. IC based circuits are certainly unfeasible, as there are no 50 watt bbd chips on the market, although op-amp based designs could be made discrete I suppose. So, yeah, just thought I'd get some feedback on this idea.
Old 10th April 2011, 04:41 PM   #2
Minion is offline Minion  Canada
I don"t see the purpose ..... an effects pedal that had high output current/voltage would not be interfacable with an amp because an amp expects a low level signal ......
Also getting Higher power transistors with the same gain as a Small signal transistor would be difficult and fets would be near impossible .....
Cheers
Old 11th April 2011, 12:53 AM   #3
oh yeah im aware of that. im talking about post-amp processing... of course this would be extremely inefficient and troublesome, but it would be interesting to have something like this, just because... i suppose it'd be fun to brag about a fuzz face capable of driving a speaker cab on its own
Old 11th April 2011, 10:22 PM   #4
I once put a full wave bridge rectifier between the output of my fender vibro-champ and the speaker.
The octave doubling effect was very interesting indeed. jer
Old 12th April 2011, 12:59 AM   #5
an excellent idea!
Old 12th April 2011, 01:55 AM   #6
That was before I started building opamp versions to get the same effect. jer
Old 12th April 2011, 02:55 AM   #7
yeah, opamp rectifiers are far superior for pure octave-y goodness, but not good for post-amp operation unless youre willing to shell out a few hundred bucks for a high-voltage Apex... or make a high voltage discrete opamp...
Old 12th April 2011, 12:03 PM   #8
I did not mean putting the opamps on the output of the amplifier.
But I did try various diode configurations for distortion sounds.
After that moved to building effects on the preamp side of things. jer
Old 16th April 2011, 09:25 AM   #9
teemuk is offline teemuk  Finland
Diode clipping in feedback loop of a power amp works just as well as it does with a generic lower current, lower voltage OpAmp. You only need to tweak the clipping forward voltage higher to make the effect any worthwhile (~500mVpeak output from a power amp is really good for nothing). I've seen this type of scheme used in several guitar amps.
Old 16th April 2011, 01:07 PM   #10
yes, im familiar with this technique, but its not quite what im looking for...
High Q or low DF Effects the same? ATTN NP & MJK mashaffer Subwoofers 1 2nd March 2010 11:43 AM
negative effects of high frequency filtration? 5spheres Pass Labs 10 31st January 2010 12:01 AM
Negative Effects of external power supply? pjpoes Solid State 7 31st May 2007 11:37 AM
Effects of high heater voltage? JoeBob Tubes / Valves 34 18th April 2003 03:21 PM
Page generated in 0.11728 seconds (80.20% PHP - 19.80% MySQL) with 10 queries
