diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   Guitar Valve Amp Output Transfomers (http://www.diyaudio.com/forums/instruments-and-amps/186607-guitar-valve-amp-output-transfomers.html)
shunt94 7th April 2011 05:54 PM
Hey,
I was thinking about building a valve guitar amp following this Schematic:
Marshall JMP 2204
I was going to put a 100w Power transformer from an old 'Sound City' amp (Making the 50w version of the Marshall amp as I don't really have that much money for valves! But can always add in the extra part of the circuit )
Basically, Its the Choke and output transformer that is worrying me.
I have a Utc a-20 Output transformer from a previous Transistor amp build and was wondering if that will do the trick?
And does anyone know of any cheap but good Chokes that I could buy?
Many Thanks!
HollowState 7th April 2011 06:47 PM
Originally Posted by shunt94 (http://www.diyaudio.com/forums/instruments-and-amps/186607-guitar-valve-amp-output-transfomers-post2530811.html#post2530811)
Surely you have the number wrong. A UTC A-20 is a 30 milliwatt line output transformer. For the choke, try Edcor or Hammond.
PeterDupont 7th April 2011 07:12 PM
Mercury Magnetics -- The Guitar Amp Transformer Company
These are among the best.
Regards, Peter
ChrisA 7th April 2011 07:15 PM
[QUOTE=shunt94;2530811]
Almost certainly "No". You will need an Output transformer with an impedance ratio of roughly about 6,000:8
Buy the transformer and choke at the same time and save on shipping. stf-electronics.com has good prices on Hammond parts. Choke for maybe under $20 and a output transformer suitable for your amp for about $75
They have metal chassis too, good prices, may as well get it all at once.
scott17 7th April 2011 07:53 PM
I bought transformers from this site when I built my Champ 5F1 clone and I'm very happy with the quality.
They have Marshall style transformers also. Great prices.
Transformers for Tube Amps
tinitus 7th April 2011 07:57 PM
Hey,
Marshall JMP 2204
looks complicated :confused:
wakibaki 7th April 2011 08:03 PM
Pick a transformer recommended for the application (50W Marshall) as it will have a critical impact on the sound you get, you can use an oversized one safely, but it will tend not to produce the distortion (typical sound) Marshall users expect.
w
Oh, this applies to the power transformer AND the output transformer.
Gilgy 7th April 2011 08:05 PM
I'm guessing the Sound City had four EL34's and you're talking about making a 50 Watt version with two EL34?
You can't simply omit two valves and use the same transformer, the impedance ratio will be wrong.
EDIT: ignore me, I didn't read the bit that said "power transformer". You'll be fine using the power transformer, just the output transformer will have a different impedance ratio from the design value on your schematic.
PeterDupont 7th April 2011 08:52 PM
It's a strict rule to know a certain degree of amp-design. I have never, ever gone to more extend than switching an output-tranni in a Super-reverb to one from a Showman just to be able to use 4 Ohm instead of 2 Ohm, loading the secondary near perfect. And the heavier iron was just disappointing soundwise.
Keep values as they are - unless tweaking with eq-components.
tinitus 7th April 2011 09:29 PM
1 Attachment(s)
from the nature of your questions I conclude this is your first tube amp, since you ask about chokes
this one looks a lot easier to build
I have seen it in several places, so I'm not sure who designed it
but I guess its a proven design
Resources saved on this page: MySQL 18.75%
