Building a ss guitar amp! Help! - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 6th April 2011, 09:41 AM   #1
Send a message via Skype™ to mgcasella
Question Building a ss guitar amp! Help!
I've been trying to get a solid state guitar amp custom built for me for a while now (I have several threads on this but the best ones are here, here, and here).
To make a long story short, apparently no one can build this for me and I may have to build it on my own. This is frustrating because I want to start marketing this amp (if people like it) and I want to focus most of my energy on the marketing side because that is where my strengths lie.
There is a guy in the some of the forums who goes by "Teemuk" and he is a wealth of knowledge (seriously - I would kill to have his brain ). He suggested that I try building a power amp first, and base the power amp off an LM3886 circuit.
My first question: Here is a power amp kit based on the LM3886 I found on ebay. I will need to modify this in order to have a Master Volume, as well as a Presence control, and a Resonance (Depth) control. I know I can build the kit but I'm not sure about the modding.
I am complete n00b when it comes to engineering my own mods - am I on the right path? Is what I want to do with this kit possible? Can I use these kits for the purposes of guitar amplification?
Old 6th April 2011, 09:53 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
In Chip Amps forum there are many who built using LM3886
There are also guys selling Kits with the chip LM3886, who can advice you
lineup
Old 6th April 2011, 10:04 AM   #3
pinkmouse's Avatar
Presence and depth should be in the preamp, not the poweramp. Other than that, you should be fine, master volume is just the normal volume pot on many of the diy schematics/modules.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 6th April 2011, 10:31 AM   #4
Look at Rod Elliot's kits as he's got some specifically for guitar use, and even some designs for cabs.
I noticed your threads discussing watts, and that "only" 100W is a problem. Unfortunately, watts are not watts, especially when it comes to marketing. Most solid state guitar amp manufacturers probably specify peak power allowing them to claim stupidly large figures. The only wattage rating that matters is "RMS". 100W will be pretty loud.
I dont know if I could recommend chip amps for guitar use. The LM3886 would probably be best in this route mainly because it has a good deal of self protection - but while that will stop it blowing up if abused (and it will be by a guitar!) it'll sound nasty as it goes into protection. If i were doing it (i dont play guitar though) I'd probably build a full solid state amp using 3 or 4 pairs of heavy duty TO-3 package transistors.
Old 6th April 2011, 10:39 AM   #5
moschfet's Avatar
Perhaps my current project is interesting for you?
Gimos50
Old 7th April 2011, 07:18 AM   #6
Thanks! I will post this thread in there and hopefully, I can buy a kit suitable for guitar stuff
Duly noted - thanks! As you can see, this is why I was never keen on actually building this thing
I understand what your saying about watts - people in the other forums were freaking out about it. My motto is: Start around 100-150 watts RMS, test with a drummer, revise amp if needed.
I may just spring for one of those kits - other people mentioned them too. We'll see what the guys in the chip amp section think about kits, what chips I should use, etc.
Gimos50
Thanks for posting your thread - I had a lot of fun checking that out last night! Do you have any soundclips or videos?
Old 7th April 2011, 08:22 AM   #7
digits's Avatar
Even that is pointless, you need to know the efficiency of the driver to know how loud it would be, i.e. how many decibels does it put out on a single Watt. most of the guitar speakers available are normally in the 15 to 30W range anyway, so unless you are building a big multidriver cab, the chipamp has enough guts to drive them. Unfortunately it will never replace the grunt of a pair of overdriven valve outputs.
Old 7th April 2011, 11:01 AM   #8
moschfet's Avatar
I have just finished the Poweramp. The preamp is not ready, but I am working on. The first board is in development and the results points to a second board
For soundclips is it to early.
Old 8th April 2011, 12:13 AM   #9
PB2 is offline PB2  United States
PB2's Avatar
I'm curious, what do you think are the best solid state guitar amps of all time?
Anyone?
Old 8th April 2011, 12:21 AM   #10
PB2's Avatar
Presence with traditional tube Fender designs is always done in the power amp feedback network.
Depth is usually part of the vibrato circuit but I don't think this is what the OP intended ... or is it?
Building a Bass SS amp out of a old car subwoofer...need advice! Audiological Solid State 11 5th June 2010 11:54 PM
Rock Amp (70's SS guitar amp) pigsnoot Instruments and Amps 9 24th July 2009 04:07 PM
Please give me a review on mi DIY SS guitar amp FPEREZ Instruments and Amps 5 28th April 2009 01:26 AM
Guitar Amp prototype SS TDA2050 project brucevicknair Chip Amps 0 29th May 2007 08:27 PM
I need a simple ss reverb for a ss guitar amp. yeto Instruments and Amps 8 18th January 2006 07:54 AM
Copyright 1999-2017 diyAudio
