Mellotron preamp schematic - Page 11 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th April 2011, 05:09 PM   #101
cbdb is offline cbdb  Canada
That bass bump changes depending on the head output resistance, is there any way you can measure the DC resistance of the heads that the input sees?
Old 26th April 2011, 05:14 PM   #102
The curve cleary shows that the slope starts about 6khz and is down about 3db at around 12khz.
The curves at the top of this page look like a higher freq. I would say 3db down at about 20khz. Which will be barely audible from old tape. I would concentrate on the 100hz to 10khz region, the HF roll off is easy.
Old 26th April 2011, 06:58 PM   #103
atmasphere's Avatar
I could measure that, although I will have to remove the tape set so I can de-guass the heads afterwards. But if I am not mistaken, the impedance of the heads at that frequency would be more important?
Old 26th April 2011, 09:57 PM   #104
Yes,I was thinking that as well as it makes it diffcult to have to convert the voltage ratios in to db's.
So, That was a geusstemation from an eyeball's perspective from the shape of the curve. jer
Old 26th April 2011, 10:04 PM   #105
I pretty much think we have it nailed.
What do you think?
I do know that on most tape decks ( at least mine ) that the playback eq adjustments are 100hz and 10khz only this preamp lacks the feature of being adjusable and it is fixed.
jer
Old 26th April 2011, 10:42 PM   #106
atmasphere's Avatar
Its no surprise to me that the EQ is only general here. The tape only moves at one speed.
Old 26th April 2011, 11:53 PM   #107
Or a variation of !
The greatest thing is the simplicity and how easy it is to work with them without having the latency and resolution with memory capacity problems that are incurred when working with digital systems.
I have everything to do all the digital stuff.
But you just can't beat the fact of setting the mixer and hit the record button and BOOM you have your take, rarther than fussing with a mouse just to do it again and loose that moment.
That is why I love tape machines.
jer
Old 27th April 2011, 05:13 PM   #108
I think its time you design something. That 100hz 10khz tape playback EQ is mostly to align different types of tape which is not a problem here. Idealy you need a test tape to test the EQ you design.
Old 27th April 2011, 08:20 PM   #109
atmasphere's Avatar
Any IEC 7.5 ips tape from the early 1970s would do for that.
Old 28th April 2011, 05:13 AM   #110
Just popped the feedback network into an opamp circuit.
Just make sure the amp is high freq/high gain
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 06:51 PM
Preamp schematic. beppe61 Solid State 49 23rd December 2015 09:16 PM
Need help: Looking for ECF80 preamp schematic Mrpong Tubes / Valves 1 21st March 2007 03:22 AM
Trying to understand preamp schematic... Saurav Tubes / Valves 31 26th October 2006 03:27 PM
Preamp schematic... Guiness Tubes / Valves 17 12th February 2004 03:37 PM
Copyright 1999-2017 diyAudio
